Old 08-09-2013, 09:50 AM   #1
Pearson422's Avatar
2013 27' FB International
Houston , Texas
50 amp to 30 amp only service
I am unfortunately am newbie to AS, we are taking delivery of a 27 fb signature, with 2 ac's and 50 amp svs. I know you can only run one ac at a time if only 30 amp is avail, but could you plug into two thirty amp plugs and pigtail both 30's into the 50 amp line and run both ac's? Or have a solution to offer.? Trying to learn as much as possible prior to walk thru. Also is the top of our 2013 rig going to have the white aluminum paint? THANKS
Pearson422 is offline   Reply With Quote
Old 08-09-2013, 10:03 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Even if you could do it, good luck finding a campground that has dual 30-amp receptacles on the pedestal.
Cats and ultraleather Airstream upholstery don't mix!
Old 08-09-2013, 10:10 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You can with one of these:
50 Amp 125/250V RV Female - (2) 30 Amp RV Male Plus Y-Adapter with Powersmart LED's - Furrion F5431RY-SB - Electrical Cords - Camping World
Assuming you can find a place to plug it into.
Old 08-09-2013, 02:23 PM   #4
1988 32' Excella
Robbinsville , New Jersey
As said it can be done but if there is a second 30amp in most cases it's for the next site, so you may not be aloud to do it.
Old 08-09-2013, 04:05 PM   #5
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
You might be able to use the splitter listed above, plug one side into the 30 Amp, and then the other to plug into the 15 amp house style plug outlet. I would have some kind of volt meter handy to make sure your getting enough volts.
My worry about doing this would be if the pedestal was wired wrong, or if the 15 amp and 30 amp are tied together. Etc...
Silverflames is offline   Reply With Quote
Old 09-02-2013, 06:23 AM   #6
Livingston , Texas
Not likely to work as the park's system should be GFI protected and plugging into them both will cause the GFI to trip.
pattydoug is offline   Reply With Quote
Old 09-02-2013, 08:08 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I am not aware of any 30 or 50 amp systems in RV parks or campgrounds that are GFI protected.
Old 09-02-2013, 09:37 AM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
It will be easier to transition at the trailer side connector from a 50amp plug to a 30 amp plug at the end of the cord.
Many folks run the A/C unit in the opposite end of the trailer so they can hear in the end in which they are sitting. Then 30 amp service would be just adequate.
Old 09-02-2013, 09:46 AM   #9
Gainesville , Florida
Yes run the ac in the other end and use a fan to move air all over. I use a tower oscillating fan for this purpose. Jim
Old 09-02-2013, 09:53 AM   #10
2012 27' FB Classic
Yakima , Washington
Welcome, you will learn that so many people here know so much about so many things. We have a 27FB with two airs. We have been in some extremely hot weather and never needed more than one air at a time. We run the air that is further away from us. Keeps us cool and not to loud.
Congratulations on your new trailer,
Mike
Mike-Gloria is offline   Reply With Quote
Old 09-03-2013, 08:10 AM   #11
Pearson422's Avatar
Houston , Texas
Thanks all for the info. Spoke to an electrician and he said "bad idea"
Have camped out a few times now and two airs are nice in 102 Texas weather. The main cabin cycles on an off nicely when Tem is hit. And have alternated Ac units on 30 amp with no prob. Now if I could solve the condensation water drops on main unit all would be good. I'm sure it's a science thing.
Old 10-07-2013, 09:50 PM   #12
2005 31' Classic
Gretna , Nebraska
On a similar but different note...Is it possible/safe to split a 50 amp/240 volt source into two 30 amp 120 volt outlets? We just had a rally at a fairgrounds where this would have been useful.
16595 is offline   Reply With Quote
Old 10-08-2013, 06:16 AM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Yes, it is possible to split a 50 into two 30s. I have seen it done. The guy built the adapter himself. I would think you could buy one ready made.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-08-2013, 09:01 AM   #14
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Pricey, but there's a commercial product for it too. Marinco 50A to dual 30A cord.
David
