Old 08-27-2017, 03:07 PM   #1
2017 27' International
Box Elder , South Dakota
5 watt solar trickle charger
Someone gave me a 5 watt solar panel trickle charger. it has a red and a black gator clip and a cigarette lighter style cord. i have two, new 12 volt deep cycle batteries on my 2017 27 foot International Serenity. Would it damage anything to attach the solar panel? where would I attach the clips?
alphamale49 is offline   Reply With Quote
Old 08-27-2017, 03:28 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
It will be fine.
RED = POSTIVE BATTERY LEAD
BLACK= NEGITIVE BATTERY LEAD
5 watts is not going the charge much but could help maintain batteries while in storage
Old 08-27-2017, 03:29 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
This may get you started.
Just to be sure they followed normal protocol I would test the red wire for positive before hooking to the battery. Once hooked up, and if correctly, you should see a slight rise in battery voltage within a few hours
2004 Excursion 4x4
Old 08-27-2017, 03:31 PM   #4
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
I just put same n m batteries in our storage lot that doesn't have shore power
Simple- just use the alligator clips to connect red to positive post and black to negative
I still don't know yet if this will only maintain or if over several weeks my hope is it brings both batteries up to full charge
dmbecke is offline   Reply With Quote
Old 08-27-2017, 04:07 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The charger will supply a fraction of an amp at best. The typical "always on" loads on a trailer pull more than that charger will supply. You still will need some sort of proper trickle charge setup for storage. So no, it will not hurt anything. It will help, but not by much.
Some math based on numbers reported in various threads (your numbers could be higher or lower):
Unavoidable loads are in the vicinity of 0.5 and go on 24 hours a day.
That gets you 12AH of discharge per day
80% of a panel's energy goes to charging so 5W becomes 4W
4W at 13.5V is about 300 ma
A normal "solar day" is 8 hours, it may be much less in some cases.
The charger at best will give you 2.4 AH per day
You are 20% better off than you were without the gizmo.
This ignores the self discharge of the batteries which should be modest compared to the unavoidable loads.
Put another way - you would do better to wire in a full battery disconnect switch as far as keeping the batteries happy. That would shut down the propane detector which is something you may not want to do.
Solar trickle charger.... drboyd Generators & Solar Power 30 10-22-2019 12:23 AM
Solar Trickle Battery Charger RupertJ Electronics & Connectivity 1 12-10-2016 05:13 PM
Solar Trickle Charger Hook-Up Chuhhuniban Batteries, Univolts, Converters & Inverters 9 08-01-2016 05:59 PM
Rigging Up A Solar Trickle Charger Chuhhuniban Electrical - Systems, Generators, Batteries & Solar 1 03-28-2016 05:29 PM
Great deal on Solar Trickle Charger ddruker Generators & Solar Power 1 08-28-2012 07:33 AM
