Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-21-2005, 07:53 PM   #1
40 amp fuses for Univolt
I have a 1971 Airstream Caravel, anyone have a source for the 40 amp fuses in the Univolt? They appear to be a standard Buss glass tube fuse but I can't find anything larger than a 35 amp locally or online. Thanks.
java71 is offline   Reply With Quote
Old 06-21-2005, 08:26 PM   #2
New Borockton , Alabama
Images: 21
AGU 40 and 50s should not be too hard to find but many RV dealers quit carrying them because most new switch converters use blade fuses. Shoot me your address via PM and I'll send you a couple. I have quite a few of them.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 06-21-2005, 08:32 PM   #3
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Home Depot has fuses of this size in the electrical department. You may want to check there...
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 06-21-2005, 08:38 PM   #4
I JUST found some right after I posted the question. At tjtrailers.com. I appreciate the offer though, thanks much.
Aaron
Old 06-22-2005, 09:19 AM   #5
68 Overlander,
My 1970 Univolt model 35 and also my friend's 1971 overlander have BUSS AGS 40 amps fuses which have a diameter of .283". Regular fuses sold at most stores are .250 diameter. We can't find any of the AGS type. Do you have some we could purchase?
Live and LET live
FrenchBern is offline   Reply With Quote
Old 06-22-2005, 09:33 AM   #6
1972 27' Overlander
Saline , Michigan
I found some a few years back at an autoparts store Murray's
Autozone may have them as well, I think they are used in some car sterio applications.
loechli is offline   Reply With Quote
Old 06-22-2005, 12:09 PM   #7
Images: 21
Frenchbern,
I only have the buss AGU 40 and 50. AGS is popular in audio applications like loechli said so maybe your local car stereo shop can hook you up.
888-828-1893
Bestconverter.com
Old 06-23-2005, 04:22 AM   #8
I tried them and no luck. I can't find them on the internet either? I am not too good at surfing. Guess i'll have to use the smaller diameter fuses.
Live and LET live
Old 06-23-2005, 09:25 AM   #9
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I found some on the net they were NOS parts. Try http://www.fuseone.com/search.asp?search=AGU40
It appears that Bussman does not make this type of fuse anymore.
They do have a circuit breaker as a replacement part for this rateing.
Try a search on Hi- Amp, it is an interesting option.
HI-AMP Circuit Breakers - Series 180
Auto, Manual, & Switchable Reset Circuit Breakers
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 06-24-2005, 04:31 AM   #10
Gary, I saw those breakers before and really like them but i'll have to build a buss distribution panel. That is a winter project for me and i'll have to build a couple of them since a friend of mine will want one also. Thanks for help.
Live and LET live
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-05-2003 11:34 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
Meter for amps davidz71 Electrical - Systems, Generators, Batteries & Solar 5 05-09-2002 10:21 AM
