Old 08-11-2011, 10:17 AM   #29
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
Darkspeed, you are fast. I suppose this could also be the reason that my trailer shell gets hot when plugged into my house (non-GFI) - the electricity has another pathway (thru the green ground wire on the white neutral buss) into the shell?
SpaceEgg is offline   Reply With Quote
Old 08-11-2011, 10:23 AM   #30
SpaceEgg's Avatar
1959 24' Tradewind
Originally Posted by Darkspeed View Post
The funny thing is in your breaker box the neutral bus is isolated from the metal box on a plastic riser...for a reason... And then the green wire defeats this isolation by jumping straight to shell ground
Oh that's hilarious!
Old 08-11-2011, 10:30 AM   #31
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
That would be a great party trick.... Lick my shell... I dare youuuuuu
Darkspeed is offline   Reply With Quote
Old 08-11-2011, 10:37 AM   #32
Darkspeed's Avatar
1972 31' Sovereign
O' yes and with the correct lack of resistance it will kill you dead - fix that
Old 08-11-2011, 10:46 AM   #33
1965 26' Overlander
new ringgold , Pennsylvania
Try driving a ground rod near the trailer or entend a wire from your homes grounging system to the trailer and read with a a.c. volt meter from the frame or body of the trailer to ground.If there is a hot wire with a high resistance ground you may be able to see it. In response to the provious post,i would think that a circuit breaker panel in a r.v. should be considered a sub-panel on an electrical system,that being said ,the neutral and ground MUST NOT BE BONDED. this if code. the ez way to test would be to use ohm meter accrss the ground and neutral blades of the plug,no connection should be seen on the meter.if a circuit is detected the first place that I would look at would be in the c.b. panel and see if it is correctly wired. This is just my opinion,I am NOT a electrician,but have a lot of years troubleshhoting electrical problems.again just my 2 cents worth.
carl
buddyboy54 is offline   Reply With Quote
Old 08-11-2011, 12:00 PM   #34
1977 Argosy 24
Milltown , Wisconsin
Your problem: the green ground wire going to the white wire buss bar is exactly what I described in post #12. Disconnect the green wire from the buss bar where the 2 white wires are and it should be OK, at least that part of the problem.
ventport is offline   Reply With Quote
Old 08-11-2011, 02:35 PM   #35
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It looks like there is a black wire going to the lower buss bar. It appears the previous owner had some interesting ideas about color coding.
Gene
electrical short
GFI Question SilverHoot Electrical - Systems, Generators, Batteries & Solar 3 07-18-2011 11:04 AM
Hwy 30A in Florida UAPachyderm On The Road... 7 06-08-2011 09:24 PM
Bypass for HWH Desikk Land Yacht/Legacy Motorhomes 3 06-03-2011 05:29 AM
'89 29' Excella-Where is the water Bypass Switch 68Glbtrotter General Repair Forum 4 05-16-2011 02:03 PM
Small Electric on-demand water heater and a 20A plug Globie64 Electrical - Systems, Generators, Batteries & Solar 5 04-14-2011 07:49 AM
