Old 06-04-2013, 01:06 PM   #1
2013 22' FB Sport
Huntley , Illinois
Question 30 vs 50 amp service
We just purchased our sport 22 2013 model. As we head off, we are reviewing campgrounds that offer either 30 or 50 amp service, some do not guarantee 30 on a 50 site. Can you use a 50 amp service with an adapter? Does the unit just pull the amperage needed? What are the guidelines? Our service person says No but other RV forums say it is no problem. What advice do you have for these newbies???
Thanks for your help.
chegard is offline   Reply With Quote
Old 06-04-2013, 01:09 PM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Here is the adapter you need
50 Amp Male to 30 Amp Female Dogbone Pigtail Adapter - $15.99
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 06-04-2013, 01:24 PM   #3
2013 22' FB Sport
Huntley , Illinois
I assume that means there are no electrical issues with hooking our unit up to the 50 with the adapter. Sorry to be such a newbie. Thanks
Old 06-04-2013, 01:25 PM   #4
Central , Mississippi
If there is a 50A and a 30A available, I always use the adaptor and plug into the 50A service. Many times, the 30A outlet has been pushed to it's limits and worn out, thus has a good chance of damaging my 30A cable. . The 50A is less used and has much bigger blades.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-04-2013, 01:51 PM   #5
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Agree with HiHo! There is no electrical issue. Will work fine. Does for us.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 06-04-2013, 01:51 PM   #6
adonh's Avatar
1976 31' Sovereign
As I understand it, A 50 amp RV power source through a 50 amp RV power cord is designed to provide 2 lines of 110 volt power to a designated 50 amp RV.
According to the data on the link above,
"The 50M-30F adapter allows you to plug your 30 amp power cord into a 50 amp power source. It adds versatility to your electrical hookups. They are Heavy-duty 10/3 ST power cords with 3-wires plus ground".
The adapter provides only one line of 110 volts to the designated 30 amp RV. Maybe others will provide a more technical response, or correct me if I am wrong.
Don Hardman
1976 31' Sovereign
Old 06-04-2013, 02:02 PM   #7
SteveH's Avatar
Common Sense , Texas
If you plug a 30 amp cord into a 50 amp outlet using an "adapter", you will only be using one side, or leg, of the 50 outlet.
If the two were tied together, you would definitely blow the 50 amp breaker on the pedestal.
Regards,
Steve
Old 06-04-2013, 02:31 PM   #8
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
One winter I was using this setup and noticed when unplugging from the 50 amp that the 30 amp trailer plug was starting to melt (had a 1500 watt heater going most all the time). Instead of just replacing it with another 30 amp plug, I went ahead and put a 50 amp plug on just for the above mentioned bigger blades and wire connectors. I do have an adapter to go back to 30 amps if needed. No more heating up with this setup
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 06-04-2013, 03:08 PM   #9
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
A 50 amp to 30 amp adapter should be in every Airstreamer's kit.
50 amp is still 120 volts AC (a hot wire, a neutral, and a ground).
As HiHoAgRV suggests, I routinely use the 50 amp receptacle with my 50 to 30 amp adapter when I have a choice. It has saved me more than once when the 30 amp breaker is weak from overuse. Hope this helps.
Other stuff to have in your Airstream:
- A 15 amp male to 30 amp female adapter.
- A 30 amp male to 15 amp female adapter.
- An extra 30 amp power supply cord.
- Electrician's tape
- A multimeter
- A receptacle tester
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 06-04-2013, 03:58 PM   #10
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We have a 50-to-30 amp adapter but have never had to use it. However, this makes sense, so now I think I will begin using the 50-amp with the step-down adapter when available. Thanks!
TB & Greg and Abbey Schnauzer
#3954
Old 06-04-2013, 04:05 PM   #11
Images: 59
I doubt this description is right. The cord itself should be 3-wires, one of which is the ground.
Which begs the question posed by the original poster. If you plug a 10 gauge cord, rated for 30 amps, into a receptacle rated 50 amps, you are exceeding the rating of the cord.
This will normally be OK, because if the amps exceed the 30 amp rating the 30 amp main breaker in the trailer should trip.
However, the cable itself is not protected. If there is a high resistance short or loose connection within the plug, dogbone adapter, or cable itself it could overheat.
Risk is low, but you you inspect the cord and adapter each time you use it and discard if it shows any sign of overheating.
Old 06-04-2013, 05:31 PM   #12
scooterbug76's Avatar
1969 27' Overlander
Northeast , Georgia
I learned something new on this thread today.
scooterbug76 is offline   Reply With Quote
Old 06-04-2013, 05:36 PM   #13
Originally Posted by SteveH View Post
... you will only be using one side, or leg, of the 50 outlet...
Exactly! On a 50A - 30A adaptor, the 50A plug has 4 copper terminals, one of them is a dummy and not hooked to anything.
Old 06-04-2013, 08:18 PM   #14
2013 22' FB Sport
Huntley , Illinois
Smile from chegard
My thanks to all of you. This opens many possibilities and we will get an adapter for all the above reasons. Since this is a sport model, our appliances are limited and I feel very confident in using the adapter now.
Thanks to all of you for your help.
