Old 10-11-2014, 04:51 PM   #1
2013 28' Flying Cloud
Rochester , New York
30 to 50 amp ?
I have a 2013 FC with a 30 amp port. Can I plug into a 50 amp supply, using a pigtail converter, without harming the electrical system?
jimgillio is offline   Reply With Quote
Old 10-11-2014, 04:55 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
You need a special 50 to 30 amp pigtail that will look something like this. If that is what you have, you are good to go!
Bob Martel
WBCCI# 5766
Old 10-11-2014, 06:49 PM   #3
Thanks - I didn't want to overpower the system but it sounds OK to use.
Old 10-11-2014, 06:53 PM   #4
richinny's Avatar
2011 34' Classic
just make sure you're plugging into an rv outlet. a home 220/240v looks the same but WILL damage your trailer.
Ricky
Old 10-11-2014, 07:10 PM   #5
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
The fifty amp plug is 240. They just go phase to neutral on two different legs, not phase to phase, so you never actually use 240 volts in the trailer. The fifty to thirty adapter just uses one phase to neutral...
So, yes, you'll be okay using the 50 to 30 adapter plug shown above...
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Samsung tv goes on & off & on & etc jump Electronics & Connectivity 22 03-03-2015 06:01 PM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
Curb Side & Front Glass Window & Clips Oceancontainer 1965 Safari 2 07-28-2003 07:04 PM
My EU2000i & gas can & boondocking Raptorrider2001 Generators & Solar Power 5 04-03-2003 09:12 AM
