Old 07-07-2013, 02:12 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
30 out/50 in!
Making change this week.
30 amp discontinue.
50 AMP install!
Will try pics and document.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-07-2013, 02:59 PM   #2
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Good luck!
BTW, how did the install of the 2nd AC go?
Sid
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 07-07-2013, 06:28 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by Sphere Guy View Post
Good luck!
Sid
Howdy, Sid!
AC 2 install on Wednesday ! Have to cut new hole on roof because existing where fantasticfan is now is too far aft to mount AC.
Wish me luck..and lift up some good vibes.
Channing
WBCCI# 30676
Old 07-12-2013, 11:47 AM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
How did your upgrad go?
I just finished the 30 to 50 amp upgrade, new cable, 50 amp auto transfer switch, one new 20 amp breaker for rear a/c and new outlet(yet to figure out what to use it for) in place of the switch in cabinet over sink. Installed auto switch twice, one side of switch didn't work took it out and rebuilt, spring and contact was out of place, my fault for not testing before install, could have been that way as I purchased new on ebay, a big slam in transit could have dislodged.
Old 07-12-2013, 01:18 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Have parts just need holesaw for honkin hole in side of AS.
However, on second thought... I am going to make a bracket to mount the 50AMP in the tray where the umbilical was stored... Hmmmm
Channing
WBCCI# 30676
Old 07-12-2013, 01:40 PM   #6
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Hey Channing,
How did you determine the hole in the rear bedroom was too far aft?
I'm looking forward to the photos, too, of your finished upgrades.
Philip
__________
Never mind the question. I see the answer on your install thread! Thanks
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 07-14-2013, 10:40 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Dave. Not installing transfer switch since we don't run generator. I suppose that's what you are asking.
Channing
WBCCI# 30676
Old 07-15-2013, 12:19 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
30 AMP breaker box out.
Channing
WBCCI# 30676
Old 07-15-2013, 01:02 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
50 AMP receptacle and plug
Channing
WBCCI# 30676
Old 07-15-2013, 04:10 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Fee-mal-Ey end. 50AMP
Channing
WBCCI# 30676
Old 07-15-2013, 04:28 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
So,
Now, where to mount the receptacle ?
The side has no strength...pushing the plug end into receptacle will flex sidewall... The weight of this big, honking plug and cable will tug at it twisting down. Hhhmmmmm.
I thought of mounting in the "umbilical" tray...not a good choice due to elements....
Channing
WBCCI# 30676
Old 07-15-2013, 05:10 PM   #12
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by cwf View Post
So,
Attachment 190985
Though I'm only dealing with a 30A inlet, I have been thinking about putting in some blocking between the inner and outer skin like the recommendation for AC units. Seems like it would stiffen the area up a bit as long as the power inlet's screws bite into the blocking, and the other side of the blocking is attached to the inner skin. I think that'll be enough for the 30A cord, not sure about a 50A one.
David
Old 07-15-2013, 09:57 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ahhh. Great ideeeeeah! Thx!!!
Channing
WBCCI# 30676
Old 07-16-2013, 05:29 PM   #14
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
When I did this I first drilled a 1/2" hole, sprayed in foam - all I could get in so it was dense. Than drilled the large hole for the receptacle. Stiffened up the whole area, lots easier and worked great.
Silver Hawk is offline   Reply With Quote
