Old 03-02-2016, 02:58 PM   #1
30 or 50 Amp?
I am restoring a 31ft 1965 Airstream and am running new electric at the moment.
Should I do a 50 or 30amp system?
I realize most campgrounds are 30 but I am thinking I can grow into the 50amp system?
I am new to this world so thoughts and advice are greatly appreciated.
beckettnole is offline   Reply With Quote
Old 03-02-2016, 03:13 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I would probably go ahead and put in 50 amp. As I understand it, 50 amp service is really two services, a 30 amp service and a 20 amp service. Assuming you are putting in one AC unit you could run the cable to the location of a future second unit and just not put in the breaker. You could put in a 4-wire shore power cable but terminate it with a 3 pin plug for 30 amp service and change the connector when/if you add the second AC unit or something else on the 20 amp input circuit.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-02-2016, 03:26 PM   #3
Images: 59
A 50a service is not a 30a and a 20a. It is a full 50a 120/240v split phase connection which will provide you with the equivalent of 100a at 120v.
I put 50a 120/240v service in my '59 and love it not because I have two air conditioners, but because it lets me run the air conditioner and the microwave and the water heater and the waffle iron all at the same time.
Old 03-02-2016, 04:07 PM   #4
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Definitely 50amp for the extra initial cost it would only be a few bucks and you wont regret it if really needed in future.
TRIPPPIN is offline   Reply With Quote
Old 03-02-2016, 06:18 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I did the upgrade and it was worth it, but I have to say I didn't do it for 50 and 50 amps. All I wanted was what my needs were: two a/c's and no need to touch the switch that allowed having two with 30 amps. We still alternate the use of one at a time 99 percent of the time, great for that 1 percent when we stop to cool the whole place down fast with two.
Old 03-02-2016, 06:59 PM   #6
Thanks for the correction. I have read many times that the RV service was not 120/240, but two separate feeds of 120 from the same phase, so line to line would be zero volts. I went looking for those references and could not now find a single one. As you said, 50 amp service is 120/240 consisting of two hot lines, one from each phase, a neutral, and a ground, fed from a dual 50A breaker.
I apologize for providing bad information. I'd still wire it up for 50A, even if I didn't plan to use all of it immediately.
Al
S/OS #004
Old 03-03-2016, 10:44 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
50 amp is the only way to go.
You cannot run a hair dryer and a/c at the same time on 30 amp.
You cannot run a hair dryer and microwave at the same time on 30 amp.
You cannot run a microwave and a/c at the same time on 30 amp.
You can run all 3 at the same time on 50 amp.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-03-2016, 12:21 PM   #8
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
If had been doing an inner skin off remod on mine, I would have gone to 50A. Even if you aren't really using it, you can always put a 30A adapter on your shore power plug and loose nothing. Start summer camping in Florida, suddenly a twin A/C system starts sounding mighty nice!
SuzyHomemakr is offline   Reply With Quote
Old 03-03-2016, 01:18 PM   #9
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
I have seen some retrofit installations where a second roof A/C was added in the bedroom and wired to it's own 20A circuit with a dedicated power cord. If 30A is not available the bedroom A/C can be run from standard outlet. When 30A is available they plug in both the 20A and 30A and run everything.
rvb is offline   Reply With Quote
Old 03-03-2016, 01:20 PM   #10
m.hony's Avatar
2013 30' Classic
I have seen that too.
TAC #MS-10
Airforums #70955
Old 03-03-2016, 01:22 PM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Most campgrounds are 50 amp. you can run a 50 amp on a 30 amp with a connector. I see no reason not to go that way.
Old 03-03-2016, 02:29 PM   #12
m.hony's Avatar
2013 30' Classic
But...
When you use a 50 to 30 adapter on a 30 amp pedestal you still have a 30 amp trailer.
TAC #MS-10
Airforums #70955
Old 03-03-2016, 05:09 PM   #13
1973 31' Sovereign
Middletown , California
No question about it, I'd go with the 50 amp set up if I was doing it.
ijustlee is offline   Reply With Quote
Old 03-03-2016, 07:54 PM   #14
1983 31' Excella
The Woodlands , Texas
50 amp..... This is hard to explain but....
When I installed a 2nd a/c I rewired the trailer to run thru everything thru 50amps service.Then ran a 2nd wiring thru just the back a/c to a 2nd breaker box and a heavy duty 20amp electric cord. If I'm at someone's home I can run everything inside on gas (refrigerator, hot water, stove) and then turning off the 50amp breaker to that a/c and use the 2nd breaker box- 20amp cord to run my a/c. NOW in saying this you CAN NOT plug in the 50amp shore service and the 20amp at the same time. This will blow up your friends house and your trailer or pop every breaker in the house. I would suggest a professional... It works great and I show off my wiring at many rallies..
Air83 is offline   Reply With Quote
Old 03-03-2016, 08:05 PM   #15
2019 30' Flying Cloud
Homosassa , Florida
50 amp will give you more flexibility with appliances and a/c.
Tater is offline   Reply With Quote
Old 03-09-2016, 03:34 PM   #16
Thank you all! I assume I will have to get a 50amp capable inlet, shore power cord and an adapter for 30amp hookups?
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
Samsung tv goes on & off & on & etc jump Electronics & Connectivity 22 03-03-2015 06:01 PM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
My EU2000i & gas can & boondocking Raptorrider2001 Generators & Solar Power 5 04-03-2003 09:12 AM
