Old 06-11-2012, 08:19 PM   #15
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Keep in mind that in a busy campground, there is no saying their service can keep up with their promised pedestal amperage... with everyone using adapters to run their rigs, you can get some big draws on the system.
Friday is offline   Reply With Quote
Old 06-12-2012, 01:30 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
You can use the 50 amp plug and you may get less voltage drop, but you will get no more amps inside than 30 because of the trailer voltage breakers.
If your shore power cable is rated at 30 amps and you plug into the 50 amp receptacle, if you start drawing more than 30 amps, you can damage the cable and a fire is possible. This is unlikely, but could happen. The breakers at the pedestal protect the cable and a 30 amp cable is not well protected by a 50 amp breaker.
We have the dogbone 50 to 30 amp adapter and have never had to use it. If we came to a CG with only 50 amp receptacles, I'd use it but wouldn't feel good about it.
Gene
Old 06-12-2012, 01:41 PM   #17
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I don't think it is worth the upgrade. It really won't get you that much more. and you may not be able to use it half the time anyway.. Unless you like rewire stuff for giggles, then go for it...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-12-2012, 01:48 PM   #18
SteveH's Avatar
Common Sense , Texas
In the simplest terms, if you have two airconditioner units, you need 50 amp service, if only one, 30 amp is fine.
By the way, a 50 amp outlet at the pedestal is the same type circuit as your home AC dryer circuit (50 amp 240 volt), but it's wired as two independent 120 volt circuits inside the trailer.
70's era Metal Ceiling Specs and R & R (Remove & Replace) Facts Distantdrummer General Interior Topics 3 06-22-2008 03:04 PM
Magnetek Series 900 Model 950 50 Amp converter / charger Specs & Features? Driver1 Batteries, Univolts, Converters & Inverters 7 03-29-2008 12:55 PM
Car & Driver Jan 07, Airstream & Benz Karyn Airstream "In the News" 14 12-04-2006 10:26 PM
Curb Side & Front Glass Window & Clips Oceancontainer 1965 Safari 2 07-28-2003 07:04 PM
