Old 07-29-2003, 04:56 PM   #1
30 amp vs. 15 amp plug?
Does anyone know what size electrical plug was original on the 60's trailers?
My '63 has a 15amp male plug. The wire it's attached to looks to be heavy gauge, comparable to what I've seen on 30amp extension cords. This makes me wonder if a PO swapped out the plug.
What's on yours?
Tom
63flyingcloud is offline   Reply With Quote
Old 07-30-2003, 05:17 PM   #2
Question
ummmmm........
Anyone else have electricity in their '60s Airstream??
Do you have a 30amp plug, or a 15 amp plug?
Tom
Old 07-30-2003, 05:34 PM   #3
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
My 64 Overlander came with a 15 amp plug and a 15 to 30 amp adapter. I don't know if this was the original plug or not. I changed it to a 30 amp plug that would allow the power cord to exit the plug at a 90 degree angle; more compatible with the electrical pedestals found in most campgrounds today.
I still keep all the adapters, including a 30 to 50 amp dogbone because you never know what you are going to run in to.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 07-30-2003, 10:51 PM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
If you cannot find out a definate answer, I would check the breaker box in your trailer. If your main breaker is a 15 or 20 amp, then you probably don't have 30 amp service.
Also, if you don't have an A/C you probably don't need 30 amp service.
-Tim
theVAP - Airstream Podcast
Old 07-30-2003, 11:51 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Question I dunno...
I plug it in & it works! Wrong end of the trailer for me!
Shari
Old 07-31-2003, 09:15 AM   #6
Thanks, Mark, Tim and Shari.
Yep, there's a 15 amp breaker. No A/C. Tempting as it is for a guy to want "more power," I guess I'll subscribe to Shari's principle for now.
thanks again,
Tom
Old 09-29-2005, 08:59 AM   #7
Trailer power wanted/needed
People always want bigger. in about everything. Most small trailers can operate very well with a 15-20 amp power supply. Adding of having an AC unit is a different requiredment. Having a 15-20 connection is far more convenient than a 30 amp RV connection. Most RV amp adapters can start fires very easily. The low amp use RVs should consider the best quality componets not ampacity. Every adaption is a potential for a poor connection and heat/fire. Frank
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 09-29-2005, 12:26 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
Shari
Actually, having traveled alone a good part of this summer, I have learned a TON since this post...
Until the International Rally, I had a 'old-style' 30 amp plug which was also refered to as an old residential dryer plug. It was not compatable with the current 30 amp outlets available at most campgrounds. I would have to use the 'old style' 30-to-15 amp adapter in order to get power. At International I had to go from my old 30 amp male to my old 30 amp female/15 amp male to a 15 amp female/30 amp male in order to plug into the 30 amp facilities available. Needless to say, this was not an ideal situation so I had a new 30 amp cord wired on at the Springfield rally by the Airstream techs in attendance. Now I have a modern 30 amp cord/plug.
Occasionally, I camp at locations that still require stepping down to 15 amp, which is no big deal. However, I found it quite entertaining that at the Antelope Rally in Medicine Bow, WY this last week...my old 30 amp plug would have worked in the old hook-ups they have there. But since I no longer have that cord (thankfully) I used the modern 30-to-15 amp adapter like everybody else. No problem...I don't have and you definately don't need A/C in that part of the country this time of year!
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
International Rally & 30 amp obdaryl WBCCI Rallies & Events 1 03-04-2004 12:18 PM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 05:12 PM
30 amp outlet john hd Electrical - Systems, Generators, Batteries & Solar 20 02-26-2003 01:54 PM
