Old 11-08-2018, 05:24 PM   #29
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sanding the prongs on a power cord is the WRONG thing to do.
When you sand the prongs you create peaks and valleys in the metal. Which reduces the contact area of the prongs. Thus reducing the ability of the prongs to carry the rated capacity. Not only that but the valleys are prone to holding moisture and dirt. This is where the corrosion occurs.
It may look nice and shiny after sanding. But it is not.
Old 11-09-2018, 01:23 AM   #30
New Borockton , Alabama
Images: 21
Probably some truth to that. The new product currently is the Smartplug that increases the contact area 20X literally over the Marinco /park power or Furrion plugs and inlets.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
50 Amp to 30 Amp adapter to 20 Amp outlet?? Reynolds Our Community 15 08-04-2017 08:16 AM
Help please! Melted prong on 30 amp plug KenSanLan Electrical - Systems, Generators, Batteries & Solar 15 04-17-2016 08:38 PM
Melted exterior floodlight cover wacnstac Lights - Interior & Exterior 14 03-26-2008 05:09 AM
Alternator wire melted airstream963 Mechanics Corner - Engines, Transmission & More... 5 05-07-2005 07:46 PM
Melted lens? Rickj Electrical - Systems, Generators, Batteries & Solar 3 01-03-2004 12:17 AM
