Old 05-16-2016, 03:38 PM   #1
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
30 amp to 20 amp adapter question
If I take my 2004 Safari with a 30 amp system to a park that only has 20 amps of power what kind of adapter do I need (if any) to make my electric system work (albeit without AC or microwave)? 30 amp female/20 amp male?
Thanks!
StreaminGeo is offline   Reply With Quote
Old 05-16-2016, 03:49 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
You do need an adapter. You need the one that you can plug in your 30 amp cord from your Airstream into one end and the other end had a male standard household plug. Some or these have a short piece of cord in between. Other are direct plug ins. Your can buys the adapters at Wal-Mart.
Brian
SuEllyn & Brian McCabe
Old 05-16-2016, 04:11 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
You got the sex right.
The micro will work just don't have everything else in the trailer on at the same time.
2004 Excursion 4x4
Old 05-16-2016, 04:25 PM   #4
2004 25' Safari
"You do need an adapter. You need the one that you can plug in your 30 amp cord from your Airstream into one end and the other end had a male standard household plug."
Ah, sounds like the one I already use to hook the rig up to the standard household three-prong (grounded) outlet. Yes?
Old 05-16-2016, 04:33 PM   #5
Tuco's Avatar
1988 32' Excella
Ojai , California
Hold all calls, we have a winner!!!!!
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 05-16-2016, 04:38 PM   #6
2004 25' Safari
Thanks, everyone!
Old 05-17-2016, 10:23 AM   #7
1968 22' Safari
Tulsa , Oklahoma
Thread Drift Alert
Let's take this one step further.
If I have a 50 amp trailer, would I use a 30 amp converter plugged into a 20 amp converter to run off standard household outlets (20 amp)?
Jay & Lisa
splyb is offline   Reply With Quote
Old 05-17-2016, 10:37 AM   #8
Paul and Tam's Avatar
1988 34.5' Airstream 345
Ham Lake , Minnesota
Jay & Lisa
Yes, you can do this, or you can buy a 50 amp outlet, an electrical box, some 12ga. wire, and a grounded 20amp plug and make your own.
This will be fine for battery charging and other light duty use. If you turn on the roof AC you may melt the adapter before the breaker trips.
Paul and Tam is offline   Reply With Quote
Old 05-17-2016, 08:32 PM   #9
daveswenson's Avatar
2012 28' International
Issaquah , Washington
http://www.campingworld.com/shopping...a-female/27986
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 05-20-2016, 07:52 AM   #10
Bell Buckle , Tennessee
Just a notr from my recent experience:
Make sure the adapter you buy has the polarity correct.
Mine was wired backwards from the factory (50 to 30 amp adapter) and had the hot wire to neutral and the neutral to hot, which means everything still works, but there's major wiring problems.
Use a multimeter to check continuity once you're plugged in.
theGMCRV is offline   Reply With Quote
Old 05-20-2016, 10:37 AM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If you decide to run the air conditioner watch that adapter closely for signs of overheat. On my Safari with the 13.5 A/C I used an adapter plug to run off my garage outlet. What happened after a day of running was the adapter plug got very hot and started to partially melt down. Needless to say a lesson was learned and obviously there are adapter plugs out their that are using improper gauge wire which will generate heat under load. I'm glad I caught my issue prior to a potential fire.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-21-2016, 06:04 AM   #12
2004 25' Safari
Thanks again, everyone!
Old 05-21-2016, 07:46 AM   #13
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Plug your 30amp cord in and plug this in the other end and then a utility extension cord into the campground circuit.
http://www.amazon.com/Camco-55233-El.../dp/B00192QB3I
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Hubbell Twist Lock 15 amp (?) Adapter vs Bargman 30 amp painterfam Electrical - Systems, Generators, Batteries & Solar 12 07-26-2015 09:03 AM
50 amp to 30 amp adapter rbsev Airstream Classifieds 0 05-04-2015 06:51 AM
50 amp to 30 amp adapter CMSmith Our Community 28 08-14-2012 09:05 AM
power adapter-30 amp-2 15 amp waynemorgan Batteries, Univolts, Converters & Inverters 4 06-11-2007 08:02 AM
