Old 09-26-2015, 12:16 PM   #15
2013 30' International
Ottawa , Ontario
I always understood that the front receptacle is for a generator and the side one is for shore power. Am I wrong? Are they interchangeable? I will admit up front I am pretty ignorant about the electrical system on the AS and I don't recall seeing any instruction when I bought the unit new.
I.G.W.
sunseeker is offline   Reply With Quote
Old 09-26-2015, 01:29 PM   #16
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
They are interchangeable, if the transfer switch is working properly
Old 09-26-2015, 04:32 PM   #17
1972 27' Overlander
Woodburn , Oregon
Originally Posted by SilverEagle6 View Post
I know what a transfer switch does, just do not know why one receptacle works and one does not. I also know when I'm dealing with an ass.
I'll seek help elsewhere.
I don't think this guy liked your information much
shineybullet is offline   Reply With Quote
Old 09-26-2015, 06:43 PM   #18
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I don't understand the above. Since the transfer switch doesn't have a way to identify what is hooked up to which receptacle, priority must be established by the receptacle, i.e. either the front or the rear must have priority. So if the front has priority, whatever you hook up to it will be the power source if both are connected and active.
The only way they could be considered interchangeable is if both generator and shore power are not active at the same time.
Am I missing something?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-26-2015, 07:06 PM   #19
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Fwiw, these are my transfer switches... (to the left of the photo)
Name:	ImageUploadedByAirstream Forums1443315958.210453.jpg
Brevi tempore!
Old 09-26-2015, 07:27 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
30 AMP shore power receptacle(s)
Al
It's basically a toggle SPDT arrangement. It's either on the front outlet or the side outlet. I have no idea what would take precedence if both outlets were energized simultaneously.
It would be one or the other, but not both.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 09-26-2015, 07:57 PM   #21
Correct, as usual. What I meant was, while you can plug shore power or generator into either receptacle, the priority will be determined by the receptacle, not the source of power. So if the OP wanted to have shore power to have priority, shore power would have to be plugged into the right receptacle and therefore they are not truly interchangeable.
Al
S/OS #004
Old 09-26-2015, 09:06 PM   #22
lewster's Avatar
DING! DING! DING!...........WE HAVE A WINNER!!!!!
Al
Old 09-27-2015, 01:09 AM   #23
1988 Argosy 32
Lomita , California
it seems to me that the rear plug should be shore power input,and the front is for generator input.
if shore power stops and you start generator to feed the load the relay will change state
(relay coil hooked to gen input) this will prevent feeding gen to power lines and haveing
VERRY grumpy line men.the relay is a SAFETY DEVICE
Your plugs and wire may be fine and not need fixing at all.
Wolfe is offline   Reply With Quote
Old 09-27-2015, 05:20 AM   #24
jackson center , Ohio
Smart plug
Check out the Smart Plug......heavy duty. Provides overheat protection.I have installed on my Flying Cloud
QUOTE=SilverEagle6;1689027]I have to of these, one front and one back. They are original equipment on my 2013. Appears the front one is no longer functioning.
Looking for recommendations for replacements, will probably do both. Leaning towards towards Marinco.
Thanks.[/QUOTE]
Schu is offline   Reply With Quote
Old 09-29-2015, 07:33 AM   #25
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
When I had a 94 LY motor-home, I had an issue with one of the ATS. I found that one of the time-delay relays was defective, so I sourced the offending part and replaced it (at the time the cost was $10).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Wiring 30 amp receptacle BlueBelle Electrical - Systems, Generators, Batteries & Solar 9 11-03-2015 11:49 AM
Rear AC receptacle only works on shore power paullovern Sprinter and B-van Forum 17 09-02-2014 11:31 AM
My first warranty issue after three weeks--faulty shore power receptacle. Zymurbrian Electrical - Systems, Generators, Batteries & Solar 10 11-13-2012 09:09 PM
Plug Shore Power into Locker Receptacle for Generator BarnacleBill Land Yacht/Legacy Motorhomes 0 07-06-2012 08:39 PM
Converting from 30 amp to 50 amp shore power blkmagikca General Motorhome Topics 8 03-28-2006 01:20 PM
