Old 11-29-2004, 12:22 PM   #1
Airrayd's Avatar
, Ontario
Smile 30 Amp Power w/o House Batteries Installed
Hi All
My "89" Excella is winterized, batteries removed and stored. (1st winter lay-up).
Is it possible to plug my 30 amp shore power cord to a 30 amp outlet I have on my garage wall so I'll have electricity on board for a 110V trouble light and to plug in a small ceramic heater? I've got some minor repairs and alterations for the winter I'd like to do. Will the converter try to charge the non-installed house batteries and cause me a problem?
Thanks in advance for all responses and help.
Great forum for us newbies to "streamin"
Cheers
Ray
"89" Excella 25'
Hensley Arrow
Prodigy Brake Controller
2000 GMC Sierra Ext. Cab
WBCCI # 6415
"Loners Unite"
Airrayd is offline   Reply With Quote
Old 11-29-2004, 12:28 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
My understanding is the converter needs a "load" ie batteries. In my trailer, my converter is on a seperate circuit - I can therefore turn it off and all (most) of the outlets still work.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-29-2004, 12:32 PM   #3
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
30 amp power and batteries
If you are not going to us any of the 12 volt stuff in the unit you can turn off or unplug the converter. I do this everytime I work in my AS and then plug the heater and tools to the wall outlets.
Good luck
David
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 11-29-2004, 12:37 PM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by dmadam
If you are not going to us any of the 12 volt stuff in the unit you can turn off or unplug the converter........
The 110 plug-in for the "Univolt" is probably located in close proximity to, if not in, the "Univolt" enclosure.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-29-2004, 12:49 PM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
All of my overhead lights run on 12 vdc. Since I a certain amount of work at night, I wired up a battery simulator up in place of the battery.
It works great.
Tom
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
house batteries wb13798 Mechanics Corner - Engines, Transmission & More... 16 02-07-2006 07:41 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
