Old 03-30-2014, 06:41 AM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
30 Amp Power Adapter
Hi,
I'm looking for the following adapter for my 30 AMP power inlet:
30A Twist Lock Female to 30A Flat Blade Male
Basically the exact opposite of the pic I attached. Cant seem to find it.
Steve
steveirving is offline   Reply With Quote
Old 03-30-2014, 08:03 AM   #2
Retired.
. , At Large
Originally Posted by steveirving View Post
Hi,
Steve
I really don't think they make such an adapter. You will probably have to make one yourself.
Old 03-30-2014, 09:04 AM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Would this work?
FP3030R-SB
Old 03-31-2014, 09:06 AM   #4
switz's Avatar
2014 31' Classic
I just installed a 30 amp (PS-13-HR) and a 50 amp (PS-54-HR) trailer power box from this outfit over the weekend at two different structures. I found a one inch conduit conversion for the top of the box at Home Depot and used a one inch offset to connect to the existing power panels. One inch is adequate for the four #6 wires for the 50 amp wiring.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 39 08-08-2018 10:58 AM
50 amp to 30 amp adapter CMSmith Our Community 28 08-14-2012 09:05 AM
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
power adapter-30 amp-2 15 amp waynemorgan Batteries, Univolts, Converters & Inverters 4 06-11-2007 08:02 AM
