Old 03-12-2003, 05:07 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
30 amp power
Closer shot
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-12-2003, 05:08 PM   #2
davidz71's Avatar
1986 25' Sovereign
Next
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 05:09 PM   #3
davidz71's Avatar
1986 25' Sovereign
Another shot showing 2 Romex lines, one snaking from the left side of trailer from the electrical reel on the side of the trailer and the other going to a 110 v. electrical box mounted in the rear.
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 05:13 PM   #4
davidz71's Avatar
1986 25' Sovereign
Side shot showing the 2 lines (white)
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 05:15 PM   #5
davidz71's Avatar
1986 25' Sovereign
Real close shot showing the 2 white Romex lines going through a clamp and into the electrical box.
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 05:19 PM   #6
davidz71's Avatar
1986 25' Sovereign
Inside circuit box with cover off.
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 05:20 PM   #7
davidz71's Avatar
1986 25' Sovereign
Closer shot of circuit box. Romex can be seen entering from a center area. Ignore the black jumper wire going to the right because it was a mistake someone made jumping from neutral to ground.
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 06:45 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
the reel?
craig
does the large romex go to your cord reel?
i would like to see a pic of that if you can.
john
Old 03-12-2003, 08:00 PM   #9
davidz71's Avatar
1986 25' Sovereign
John,
One of the Romex wires hangs down and then goes off to the left. It goes between the inner skin and a partition, past the water heater on the skin side and through another partition which is then accessible from the roadside compartment behind the reel compartment and the water heater outside door. It then goes through the left side of the compartment partition wall, drops down a few inches and goes into a galvanized electrical box. A line runs out this junction box and into the corded reel. Lets see what reel pictures I have:
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 08:01 PM   #10
davidz71's Avatar
1986 25' Sovereign
Next reel pic.
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 08:02 PM   #11
davidz71's Avatar
1986 25' Sovereign
Hose reel door.
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 08:04 PM   #12
davidz71's Avatar
1986 25' Sovereign
More including the water hose.
Craig
AIR #0078
3.73 rear end
Old 03-12-2003, 08:05 PM   #13
davidz71's Avatar
1986 25' Sovereign
Close view again but of water hose, reel not visible in this photo.
Craig
AIR #0078
3.73 rear end
Old 03-13-2003, 04:35 PM   #14
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
if he is not getting power. the reel has some brushes in it and they are not rated at 30 amps and as a result the hot side burns out . had that problem one miserable hot day in chattanoga. i took my reel out after i replaced the contacts twice . after you remove the reel you can wire direct to the power panel and shove the drop cord in the cavity where the reel was. no more problems. did the same on my motor home . lol
al
wb13798 is offline   Reply With Quote
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 05:12 PM
30 amp power cord trouble davidz71 Electrical - Systems, Generators, Batteries & Solar 1 03-12-2003 05:29 PM
30 amp outlet john hd Electrical - Systems, Generators, Batteries & Solar 20 02-26-2003 01:54 PM
