Old 09-15-2006, 09:58 AM   #1
Cracker's Avatar
Pittsfield , Maine
30 amp Plug Differences
I just bought a new generator for home standy use and the 30-amp/120 volt receptacle is of the 3-prong, twist lock design (---similar to my marine plug.) Is there any reason for the difference in design between our Airstream 30-amp 3-prong plug, with the wide flat angled blades, and the twist-lock plug? Can I buy an adapter plug or pigtail to make the connection?
Cracker
Cracker is offline   Reply With Quote
Old 09-15-2006, 11:33 AM   #2
Images: 59
Not a problem. I think the difference is the trailer plug is a NEMA TT-30, and your generator is an L5-30R.
Old 09-15-2006, 11:44 AM   #3
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Hello,
go to home depot or lowes or any electrical store and tell them what you want to do and they will set you up. But you should not need 220 in a trailor..
bobchevy89 is offline   Reply With Quote
Old 09-15-2006, 03:52 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Adapter Pigtail
I bought an adapter to convet the big wide blade 30 amp plug to a regular outlet at Wal-Mart or Camping World. Don't remember.
Buy two. Keep one for when only 15 amp plugs are available. Cut small end off one and head to the Home Depot for a replacement plug to fit the generator.
Never be wanting for juice again.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 09-15-2006, 04:14 PM   #5
Cracker's Avatar
Pittsfield , Maine
Adapter
Mark:
Have you seen an adapter that will mate these two different plugs? I'm familiar with the 15 amp adapter - which I normally use at home (---and at rallys!) to keep the batteries charged. I'll admit that I haven't checked out Home Depot yet - 26 miles away - although I do frequent that toy store quite often!.
Cracker
Old 09-16-2006, 06:03 PM   #6
Cracker's Avatar
Pittsfield , Maine
OK - I visited Home Depot today but all I could find was a female receptacle for a travel trailer - i.e., our standard Airstream plug. I'm not ready to dig into the bowels of the generator just yet to change the plug so I plan to keep looking for an adapter.
Cracker
Old 09-18-2006, 06:29 PM   #7
Cracker's Avatar
Pittsfield , Maine
Adapter Found
I visited my local RV supply house today and found the conversion plug. Most any RV supply should carry them. Problem solved!
Cracker
Old 09-18-2006, 07:45 PM   #8
nilesrob's Avatar
Marietta , Georgia
Images: 12
Originally Posted by Cracker
Mark:
I had a similar situation. I took a regular 30 amp RV extension cord and switched the male end to a twist lock for connection to the generator. That way I can leave the generator mounted on the front of my Excursion, and just run this as an extension cord back to the AS power cord. No fuss, no muss.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
Meter for amps davidz71 Electrical - Systems, Generators, Batteries & Solar 5 05-09-2002 10:21 AM
