Old 08-09-2016, 12:57 AM   #43
1979 23' Safari
Wayland , New York
As a price point for those thinking it's not that big a difference.
Assuming say 125' run. <3% voltage drop. Meeting Table 310.16 Allowable Ampacities. Copper wire. (Aluminum can be used but requires larger wire)
For 30 amp you could get away with direct bury UF-B cable, though I'd still put it in conduit, the UF-B in 6/2 would cost about $155.
For 50 amp you'd end up needing to use 4 gauge cable USE-2. You'd need 4-4 cable equivalent, since you need an extra conductor, and would cost around $415. You could save a small amount by using a smaller ground, which is allowed if installed properly. This is 4 separate cables though so will require a little more labor.
That's a $260 difference.
But a $260 diff vs doing it twice!?
If you can square these numbers with the electrician, buy the wire yourself, rent a trencher, you could probably save some money having him make the final connections.
USE-2 and UF-B can both be direct buried but I'd put them in conduit. <$100 in materials. The 4 gauge will be fun pulling so go with a larger conduit(1-1/2 for more pulling room, 30 degree bends to make it easier).
Don't forget a permit! Hate to have to rip it all out!
Don't forget 811 call before digging.
Old 08-09-2016, 03:25 PM   #44
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have two 50 amp boxes at home. One next to the shed I had built for the trailer. I keep the trailer plugged in at all times since I've got a high quality (non Airstream) Magnum inverter/charger, as well as a (redundant) PowerMax PM4B 60 AMP 4 stage Converter/Charger. I installed an additional Jamestown box adjacent to my driveway that covers the waterfront...50 amp, 30 amp, and 20 amp with GFCI. I use this box when I'm getting ready to launch for a trip, and it gives overnighters full electric as well. The biggest hassle in the installs is pulling that big cable from my main panel. The pain was worth it.
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-09-2016, 03:47 PM   #45
Gainesville , Florida
Neat setup!
Service snafu $&!&& and which battery is which amirm Sprinter and B-van Forum 25 07-04-2016 09:19 PM
Magnum MMS1012 1000W Pure sine Wave Inverter w/50 Amp Charger &amp; Remote exallen Airstream Classifieds 0 06-05-2016 03:25 PM
Goucho couch,original am/fm 8 track &amp; lots of wood &amp; aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
Samsung tv goes on & off & on & etc jump Electronics & Connectivity 22 03-03-2015 06:01 PM
