Old 08-30-2015, 02:15 PM   #1
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
#30 amp hooked to house 110
Is it possible to run my AS 30 amp line with adapter on my house 110 or do I need to add a 30 amp circuit? I had no problems previously, but kept blowing cir. breaker last time running my ac in 100 deg temp. My grounded orange extension cord with excess coiled on grass in the sun melted and fused into orange blob. We only hook to house for a day to prep for a trip and clean on return. Oh, and I get lost in electrical mumble beyond screwing in a light bulb....early childhood trauma involving a hot socket and a toy gun.
Longboard6 is offline   Reply With Quote
Old 08-30-2015, 02:26 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You should never use an extension cord and try to run your A/C. Unless it is a 30 amp or larger rated extension cord.
If you are lucky you may not have ruined the compressor motor in the A/C unit.
A 30 amp/120 volt RV outlet is recommended when using the A/C. Even then the wire sizing must be correct to prevent any significant voltage drop. Depending on how far the RV receptacle is from the power panel in the house will determine if the wiring run must be larger than #10 AWG wire.
Old 08-30-2015, 02:31 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Running the air conditioner draws a lot of power and when it cycled, the extension cord could not carry the startup amp load and the wires heated up and the insulation melted.
Your home circuit breaker panel needs a single slot available into which a 30 amp breaker could be installed. Then a wire would be pulled to a spot that you can access with your trailer power cord. The proper outlet for the trailer cord would then be installed. If you are unsure how to do this, get an electrician.
While #10 copper wire is rated 30 amps, if the run to the new power outlet is very far (over 25'), then I would suggest #8 copper or even #6 copper wire to reduce the voltage drop associated with high current draw that resulted in heating the wire in the extension cord.
I just acquired a 100' three #10 copper conductor extension cord that is rated for only 15 amps due to voltage drop. That translates to a 1,800 watt electrical load. It would have overheated trying to start the typical Airstream airconditioner.
Old 08-30-2015, 02:47 PM   #4
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
If you decide to have a 30 amp outlet wired to your house, be absolutely sure the electrician knows to wire it for 120 volts. Too many so called electricians think all funny looking plugs have to be 220. Lots of Airstreams have been fried that way.
Tell him/her you need 120 volt power, and make him/her prove that's what you have before he/she leaves.
Old 08-30-2015, 03:15 PM   #5
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
My electrician installed a 30 Amp breaker & a dedicated plug just below the breaker box. I use a 30 Amp extension cord that plugs into my Airstream cord, it's the perfect set up for driveway loading/unloading or maintenance.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 08-30-2015, 03:17 PM   #6
Images: 59
I used to run my ac from a single 20 a outlet in my garage. No extension cord, just the regular 30a cable and an adapter plug.
I also have my ac wired through a 30a Surge Master. Despite this I still popped a breaker after about 24 hrs of operation. The adapter plug was hot as a pistol.
Cost to run #10 wire and a 30a outlet was $100.
Old 08-30-2015, 04:14 PM   #7
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Saying the above answers in reverse; Do not use the microwave or air conditioner in your trailer when connected to the house until you upgrade your circuit to 30 amp.. Lights, TV, and fans are OK. Your converter will keep you battery charged if it is a multi-stage unit. If not, then you should disconnect the house power once fully charged to ensure you don't overcharge (and ruin) the battery. Be sure to check the water level in your battery at least every two weeks.
SeeMore is offline   Reply With Quote
Old 08-30-2015, 05:31 PM   #8
aftermath's Avatar
Spokane , Washington
I hook up to the garage via an extension cord and an adapter. I am hooked up to a 20 amp circuit with 12 gauge wiring in the garage. I do not run the AC. I turned it on once and noticed the the voltage meter was reading 119 V. I returned about 45 minutes later and saw the voltage had dropped to about 108. I turned everything off and looked at the extension cord. It was warm, very warm but no where near melting. The current draw on an AC is too large for a smaller circuit. It will result in voltage drop, heat build up and possible damage to the AC.
If you are going to use the big appliances you must be plugged into a 30AM line and and extension cord has to be rated to carry 30 amps. Anything less than this and you will be asking for trouble.
aftermath is offline   Reply With Quote
Old 08-31-2015, 10:54 AM   #9
2007 28' Classic
Ivanhoe , Virginia
Ems
I may be a little off the subject of this thread but I assume Airstreams do not come from the factory with built-in
EMS (Emergency Management System)? We use a portable one, always, and it has saved us more than once when campground electricity was faulty or voltage too low. A nuisance to have it shut us down, temporarily, but worth it in terms of appliances. We haven't taken delivery on our Airstream yet so there are a lot of things we don't know about them.
horseylady is offline   Reply With Quote
Old 08-31-2015, 11:23 AM   #10
richw46's Avatar
Lexington , Kentucky
What does the EMS do, provide temporary power? Your AS will have an inverter that converts the 12VDC battery power to 110VAC. You won't be able to run the AC or microwave but you will be able to power small appliances that don't draw too much electricity.
Maybe you mean the EMS is a circuit tester/surge protector? You should have one of those too. It checks the CG connection to make sure it's not reversed wiring, open ground etc.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-31-2015, 11:26 AM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
You can run everything except the air conditioner. Your house receptacle is only 15 or 20 amps.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-31-2015, 01:06 PM   #12
Longboard6's Avatar
At first I thought your EMS was going to be about CPR on me after I electocute myself. Thanks for not making fun of my electronic disfunction. I will look into the EMS
Longboard6
Old 08-31-2015, 01:24 PM   #13
Boxite's Avatar
2008 22' Sport
AMPS is like GALLONS of water. VOLTS is like PRESSURE (PSI).
Volts multiplied by Amps equals WATTS (which is the ability to perform Work, similar to 10 gallons per minute at 50 psi.)
So... 30 Amps, says nothing about VOLTS. If you hire an electrician worth his salt (like an IBEW member or other journeyman) then he will know to determine the voltage required when he makes the circuit. And you should specify that for RV use, what you want is a 30 Amp, 120 Volt circuit, properly grounded using a 30 Amp RV receptacle.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-31-2015, 02:31 PM   #14
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
house outlet - 20 amps.
good for a few lights and such....No A/C...NO MICROWAVE
you want to do all that - go purchase some (#6 best) or #8 gauge stranded wire,
makeup a cord that you could plug into the clothes dryer outlet...or suitable large
amperage outlet(if available).
Safety - get an Electrician to help you.
kennethowens is offline   Reply With Quote
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 39 08-08-2018 10:58 AM
OK to Run AC on house 110 volt? Chasmorgan Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-30-2009 08:03 AM
Trying to get 119 & 110 Dishnetwork bilby05 Computers, Internet & Satellite 12 04-28-2009 10:06 AM
100th Post & Hooked Whizzo Our Community 9 08-10-2008 09:51 PM
12v & 110 1969 Sov 31' CJ of Okla Electrical - Systems, Generators, Batteries & Solar 3 10-02-2007 10:50 AM
