Old 09-01-2015, 04:15 PM   #29
1974 Argosy 20
Kooskia , Idaho
Originally Posted by gator.bigfoot View Post
All breakers are designed to trip at 80% of full load current. That means that a 15 amp breaker will trip at 12 amps and a 30 amps breaker at 24 amps.
No, that is not true. They cary their rated current, but code limits their long term load (defined as 3 hours or more, continuous) at 80% of rated capacity.
In other words, a 30 amp breaker will cary 30 amps, but only is code allowable for loads less than 3 hours long. In the event the load is more than 3 hours, the 30 amp breaker is only allowed to cary 24 amps. (80%). That code spec does not mean the breaker will or should trip at 24 amps.
Old 09-01-2015, 05:59 PM   #30
Images: 59
Originally Posted by DavidsonOverlander View Post
Perhaps an electrician will correct me, but it's actually the other way around. If you have a modern 4-wire dryer outlet you have 2 hot wires (red and black, each with 120 volts to provide the 240 volts), a neutral wire and a ground. You would use one of the hot wires, the neutral, and the ground to create a connection that would be 120 volts.
If it's an older 3-wire outlet then it wouldn't work because you don't have a neutral wire. A neutral wire is not required for many 240 volt applications. If you went black to black, green to bare, red to white you would have a 30 amp 240 volt supply.
You're correct. My point was that making up a dogbone adapter is easy if you understand the all the ins and outs of split phase wiring.
If you know that you just need not use the second hot leg, then you don't need help from me or anyone. Same with the old style three wire (120v adapter not possible).
So the lesson would be - don't mess with it unless you know what you're doing. We can all agree on that.
Old 09-01-2015, 06:31 PM   #31
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Note...I said "MAKEup" a cord.
Implies that a person understands what MAKEup would mean.
True, a Dryer connector is 240volt.
True, a 30amp cord is 120volt.
True, a 50amp cord is 240volt.
The fellow is melting extension cords & tripping breakers
in 100 degree weather in his driveway.
He wants(maybe needs) to use the trailer in the driveway.
Making up a cord of suitable size (awg#6) is....A WAY.
He may not have $1000 for an electrician.
That is providing a person knows how to MAKE a cord.
If a person has never made a cord...then they may want to get help.
kennethowens is offline   Reply With Quote
Old 09-01-2015, 07:08 PM   #32
2015 16' Sport
Portland , Oregon
I have a humongous 20A yellow extension cord I got at home depot. weighs about 25lb and has a neon pilot in the female end. I use a simple adapter I also got at home depot for about $3 to plug into the house. That said, I don't run that AC at home.
leedav is offline   Reply With Quote
Old 09-02-2015, 07:57 AM   #33
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
3 wire vs 4 wire
3 wire dryer outlets do have a neutral. The heating element is The only 240 volt device in the dryer, everything else is 120 volt. The difference is in the 3 wire the neutral and ground wires are connected together. In a 4 wire system they are separate.
TG Twinkie is online now   Reply With Quote
Old 09-02-2015, 01:33 PM   #34
Wolf Alaska's Avatar
Madison , Alabama
This is the other side of the discussion.
Board, I'm in my trailer, it is 93 outside, the AC is on, I'm cool. The power cord is plugged into a 120 VAC receptacle, backed by a 20 amp breaker, on the outside of the house.
I've done this since May 2009 with no problems.
Voltage in trailer with compressor engaged & high fan is 118.5 VAC.
Here's what makes this possible. A big dogbone adapter into the house 120VAC receptacle. The dogbone is plugged into A 25' RV 30 amp extension cord plugged into a 1200 joule surge protector connected to trailer's 30amp powercord. All connections have dialectric grease.on them.
Coleman 15,000 BTU AC runs @ 12 amps & has easy start capacitor kit. Dometic microwave runs with no problem at all. It is either/or on these. Can't run both at same time. Just switch AC to fan, then use the microwave. Finish cooking, then set AC back to Cool.
I have contacted 3 electrical outfits overthe years with NO interest in coming out here to put in an RV outlet. So, I'm "getting by so far with no bad results".
See, I too have the same fatalistic .mind set of those RV folks who run down the highway with the propane in use.
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 07-12-2016, 01:43 PM   #35
Wetumpka , Alabama
This is an old thread, but people are apparently still interested in the topic. One thing NOBODY has mentioned that makes it IMPERATIVE that you DO NOT use a dryer outlet to power your 125 volt (nominal) 30 A RV is:
DRYER OUTLETS ARE FUSED (Circuit Breaker) AT 50 A. FIFTY!!! Count them!
You are wanting to supply your 30 A RV with power but the dryer circuit breaker will not trip if you overload the 30 A RV.
So, IF YOU INSIST ON DOING THIS, have a qualified person change the breaker to a 30 A 2 pole breaker. It still isn't the right way, but at least if your air conditioner or microwave decides to "bzzzzt" you may trip the breaker in the house before you overheat the wiring in your RV.
Sorry for the shouting, but this should have been mentioned very early in the thread. Don't connect your 30 A RV to a 50 A circuit! Not a good idea at all.
Best wishes,
Chuck
Cadillac84 is offline   Reply With Quote
Old 07-12-2016, 01:58 PM   #36
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
One warning you failer to mention is that a dryer is a 220v appliance. Nothing in any Airstream is 220 volts! Attempting this will rrsult in the loss of almost everything in the coach!
Old 07-12-2016, 02:28 PM   #37
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Most dryers use a 30 amp source. It is your electric range that needs a 50 amp source. Both are 240 volt AC. They should not be used as a power source for your RV.
The idea behind a circuit breaker is to protect the wiring. Not to protect individual devices. Your RV is an individual device. Within that device is a power panel sized appropriately for the protection of the devices within the RV.
Protection of Life and the Safety of you and others should be the highest priority when powering any RV.
Old 07-12-2016, 02:32 PM   #38
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Best wishes,
Chuck
Isn't there a 30 amp main breaker in the trailer that would trip first? There is in our trailer. The only wiring that is not properly protected is the 30 amp extension cord leading from the dryer outlet to the trailer, and even this is not an unusual situation. You would be doing the same thing if you used an adapter to plug your 30 Amp cord into a 50 Amp receptacle at an RV park.
This, of course, would assume that whoever created the plug to adapt the RV plug to the dryer outlet understood that only one hot wire from the dryer plug should go to the trailer.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-12-2016, 02:35 PM   #39
1964 26' Overlander
Milton , ON
True, but the RV plug won't fit into the dryer outlet anyway so an an adapter must be created. That's where you would ensure that you only connect one hot, one neutral and one ground to the RV. The other hot wire would not be used.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 07-12-2016, 03:20 PM   #40
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Right... i was thinking someone might try to cram a dogbine in the old 30amp dryer outlet which will fit!
Old 09-03-2016, 12:20 PM   #41
Merritt Island , Florida
Garage power adapter
Does anyone know if a power cord adapter is available with two 15 volt male ends and one 30 amp female end which would allow a 30 amp power cord to be plugged into two 15 volt power outlets? Is this combination workable?
wacocar is offline   Reply With Quote
Old 09-03-2016, 12:32 PM   #42
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Not really.
It really does not work safely that way, especially if the two 15 amp plugs are from opposing phases.
Fwiw, I have run my trailer for days at a time on 15 amp service and never tripped a breaker. (11,000 btu air conditioner)
I run it for months at a time on a 20 amp breaker.
Gradiens super tenui glacie.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 12:40 PM
OK to Run AC on house 110 volt? Chasmorgan Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-30-2009 09:03 AM
Trying to get 119 & 110 Dishnetwork bilby05 Computers, Internet & Satellite 12 04-28-2009 11:06 AM
100th Post & Hooked Whizzo Our Community 9 08-10-2008 10:51 PM
12v & 110 1969 Sov 31' CJ of Okla Electrical - Systems, Generators, Batteries & Solar 3 10-02-2007 11:50 AM
