Old 03-11-2015, 02:46 PM   #1
jasperkins's Avatar
2012 27' FB Eddie Bauer
colorado springs , Colorado
30 amp fuses keep blowing
What timing. We are in Ouray Colorado, with our 8 month old and now have electrical problems. Our 2012 28' keeps blowing the 2 30 amp fuses.
To narrow it down, I have:
- unplugged from shore power
- turned off all breakers
- unplugged all receptical and microwave from outlets
- put trailer in store mode
- replaced with 2 new 30 amp blade fuses
- put trailer back in use mode
- both 30 amp fuses immediately blow!
Not much more in process of elimination. reaching out to forums before I haul our trailer to a nearby town for repair. I think there is a bigger problem, as even when on shore power, the whole trailer electrical turns off. I then have to turn off the breakers and back on to get the electric to stay on for a few minutes.
jasperkins is offline   Reply With Quote
Old 03-11-2015, 02:55 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Have you checked the polarity/grounding and voltage output from the post?
MICHAEL
Old 03-11-2015, 03:01 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Check the electrical cable connecting the trailer to the tow vehicle for damage.
Try disconnecting the trailer from the tow vehicle and see if the problem goes away.
Old 03-11-2015, 06:43 PM   #4
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Not to scare you, but be careful turning the power on for a few minutes knowing that they will eventually blow. You may have a "hot" skin condition, which is usually when a HOT (positive) 12V wire is touching a ground connection somewhere (or vise versa, and a 12v Ground wire is touching a positive wire). If that's the case, you could feel a tingle getting in and out of the trailer when your feet are on the ground and your hand touches the door handle. Because you've got the little one with you, just wanted to mention this; I'd keep the power off until you figure out what's going on; those fuses are blowing for a reason (to protect you).
trekerboy is offline   Reply With Quote
Old 03-11-2015, 07:28 PM   #5
richinny's Avatar
2011 34' Classic
are these two 30 amp fuses in the converter?
Ricky
Old 03-11-2015, 08:15 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The fuses on the converter blow when you have a reverse polarity situation. Usually caused by the battery(s) being connected incorrectly.
Has any work been done on the coach?
Old 03-12-2015, 06:15 PM   #7
Harvey Cedars , New Jersey
30 amp fuses blowing
I had same problem last spring. Turned out one of my batteries had a shorted plate in the battery. Since batteries were at the end of their lifecycle, I replaced both, and haven't had problem since.
eklein82 is offline   Reply With Quote
Old 03-13-2015, 08:49 PM   #8
2014 27' FB International
Okanagan Falls , British Columbia
I have the same problem on shore power IF I am running the air conditioner / heat pump and have the hot water heater on electric rather than propane. The air conditioner needs 20 plus of your 30 amps and your electric hot water heater needs 10 plus of your 30, throw in any other electrical stuff and you are blowing fuses. Mine is a 2014 International Stirling.
brian2424 is offline   Reply With Quote
Old 03-13-2015, 09:05 PM   #9
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I think you mean the circuit breaker is popping.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 03-15-2015, 07:55 AM   #10
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
To further this path even though we don't have confirmation from the OP that these are the fuses in question...
I had a similar issue with my converter in previous Airstream that I owned. The Iota converter would blow one or both of the blade fuses occasionally. I dealt with it. Then, it stopped blowing them, but would instead go to top-off charge and once topped off, would never kick back on. I had to remove one of the battery cables, put it back on, and then it would charge again. I discussed all of above with a very knowledgeable guy at Iota and he explained that there was an internal issue with the converter. They could repair it but would be just as costly as a new one. So that's what I did...replaced the converter and no more issues.
WineStream is offline   Reply With Quote
Help! Im boondocking and fuses keep blowing AUTAILGATER Batteries, Univolts, Converters & Inverters 13 04-15-2011 02:10 PM
Fuses blowing, battery sparking - 69 Overlander 27' mcstubbs Batteries, Univolts, Converters & Inverters 5 07-23-2009 04:27 AM
Blowing 30amp Fuses takeachance Generators & Solar Power 2 06-14-2007 12:43 PM
Running Lights blowing fuses neil ervin Electrical - Systems, Generators, Batteries & Solar 11 04-30-2006 07:37 PM
charging/blowing fuses on the Bambi jonoflewis Electrical - Systems, Generators, Batteries & Solar 7 12-19-2005 06:04 AM
