Old 01-27-2006, 08:15 PM   #15
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by campcollector
I believe the latest switch was in the 2002-2003 product lines. They moved the bumper hookup to the side. I have a 2003 model that came right during production change so I have a rear bumper with the electric cord door only, and the side of the trailer uses the Marinco receptacle.
I remember seeing a picture of johnhd's trailer/power cord and noticed that it had the connection on the side near the rear. The connector was yellow and looked like a marine connection. I didn't know if that was something that he wired up or the way the trailer came.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-27-2006, 08:49 PM   #16
Fullerton , California
Originally Posted by Creampuff
Lynn:
Well now that Don was so kind I'll be keeping it original, and installing a NOS cover. I believe they were either $5 or $10. I'll call over and find out how many they have sitting in the bin and cost. I saw at least 4.
Since you are close by I could get them shipped together. I'm down to Orange often to hang with Uwe.
BTW I'm selling the wall furnace form my '57. Need one?
That would be very appreciated Murray. We would like to run by Uwe's and see his latest progress. What is a NOS cover?
Not sure about the heater. Our's had been removed by a po. The layout on our flying cloud has a curbside sink and stove instead of the fridge with the heater on the side by the door. We may opt to go with something smaller as we have no good place to put a large wall unit.
Thanks, Lynn
cloud55 is offline   Reply With Quote
Old 01-27-2006, 08:56 PM   #17
Originally Posted by eubank
Oh, gads. Just when I thought the world was not as crowded as I'd imagined, along comes another Lynn ...
Lynn
I had noticed there was another Lynn on this forum. I really don't run into a lot of other Lynn's just Linda's. Since you were here first I can always be a Lyn with one n or cloud55...
Old 01-27-2006, 10:13 PM   #18
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
2014 25' Flying Cloud
Malibu , California
Images: 60
[quote=cloud55 What is a NOS cover?
Not sure about the heater. We may opt to go with something smaller as we have no good place to put a large wall unit.
Thanks, Lynn[/quote]
NOS stands for New Old Stock, meaning an original equipment part thats old but not used.
I just put the wall furnace on Ebay as my Plat Cat vented catalylic heater arrived today- but we can discuss heaters offline.
I will check out the B'man inlets and PM you.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 01-27-2006, 10:16 PM   #19
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
nope that wasn't me craig.
mine has it's own compartment near the street side rear. there is a pull out tray to wind it up on. the cable enters through a bushing in the side of the compartment. directly above that it transitions to romex in a junction box.
john
you call them ferrets, i call them weasels.
Old 01-27-2006, 11:00 PM   #20
Johndigbydog's Avatar
1966 22' Safari
Eagle Lake / Eastport , Florida / Maine
Why don't you just contact Marinco? I have one on the 50 amp inlet on my Monaco pusher motorhome and it was a retro install, the origional cord was a permenant attach and I hated it....A dealer made the change and installed the placard as well. John
Johndigbydog is offline   Reply With Quote
Old 01-28-2006, 07:00 AM   #21
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
The power outlet has been done in a number of configurations over the years.
My '53 Flying Cloud had an outlet on the rear just above the bumper on the streetside that allowed a power cord to run through it. As the PO had changed it out to a piece of Romex with a standard three-prong connector on it, I changed it to an "outdoor" three prong wall plug that a standard 15A extension cord would fit.
My '57 Overlander had a similar setup to the Flying Cloud, but it actually had the "outdoor" outlet already installed from the factory.
My '61 Bambi had the power cord and electrical box on the street side under the sink unit; accessed through the trunk opening.
My '70 Safari Special 23' had the power cord accessed through the box formed by the bumper which also doubled as sewer hose storage.
My '85 motorhome had the cord in it's own compartment on a spring-loaded reel behind the tag axle on the street side.
My '94 34' tri-axle has the cord in it's own compartment on a manual slide-out strorage tray on the street side (identical to the setup on john hd's '92).
Roger
Old 01-28-2006, 03:07 PM   #22
davidz71's Avatar
1986 25' Sovereign
john
Sorry John, thought it was your trailer.
Craig
AIR #0078
3.73 rear end
Old 01-30-2006, 10:18 PM   #23
Creampuff
Creampuff's Avatar
1971 31' Sovereign
Malibu , California
Images: 60
Thumbs up Two Rivits- Way Up!
Originally Posted by markdoane
Murray,
If all you need is the original plug, you can have mine. It's a Bargman 60-Q-3P, 120V, 35a.
I want to publicly thank Don for his generousity. The plug arrived today and by this weekend the Flying Cloud will again have a heartbeat.
TWO RIVITS- WAY UP!!
Murray
AIR #189
Old 01-30-2006, 11:08 PM   #24
another big thanks!
Murray are you going to just cut the male end off of a modern 30 amp rv supply cord and attatch the old bargman??? Also...anything I should know before I do it?
And another public thank you back to Murray for finding the ONS plug ins!!!
and also for telling me what ONS stands for.
Lyn
Old 01-31-2006, 09:45 AM   #25
Creampuff
Creampuff's Avatar
1971 31' Sovereign
Malibu , California
Images: 60
NOS Lynn, NOS!
Lyn
That would be N.O.S. (new old stock). The NOS Bargman power inlets I located are the MALE end that mount into the trailer skin. I will fabricate a new 30 amp shore power cord from a stock park cord available at my RV dealer and installing Markdoane's female end.
Murray
AIR #189
Old 01-31-2006, 10:10 AM   #26
understood
I understood that the ones's you located are the male ends that are attatched to the trailer. We have two of those on ours now and will have the NOS ones from you to change those out. The female end that Markdoane sent you is the same as the one that we finally hunted down. It sounds like what I am planning is basically the same...using the new style 30 amp cord and replacing the end that connects to trailer with the old style. Just wanted to run that by you and see if that was what you planned to do as well.
Thanks, Lyn
Old 02-06-2019, 04:31 PM   #27
Berkeley , California
I know this is a really old post, but you had (have??) the exact thing I need - the female plug for my '57 Flying Cloud. You don't still have it kicking around, do you?
EveryCloud is offline   Reply With Quote
Old 02-24-2019, 05:36 PM   #28
Creampuff
Creampuff's Avatar
1971 31' Sovereign
Malibu , California
Images: 60
Unfortunately, up until Nov. 9/'18 I did still have 2-3 of them- however I lost them and 3 vintage AS's in the massive Woolsey Wildfire that swept through our ranch in Malibu. We escaped in our 2016 Int. Signature 25.
I had hoped the one of the two on the '57 FC was serviceable and I could salvage it for you- but they were both toasted as well.
Try calling Steve at Vintage Trailer Supply and see if he has any suggestions. Otherwise you're stuck with a modern conversion.
Murray
AIR #189
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Trailer Life RV Campground Finder Pahaska Our Community 12 08-03-2002 08:45 AM
