Old 08-21-2004, 05:47 PM   #15
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Safari Tim
..Sometimes the neutral on a 220 circuit is smaller gauge than the two 110 leads since it's not required to carry the same amount of current...
Tim,
I believe you meant to say the ground. There is no neutral on a 220 vac circuit.
Tom
Old 08-21-2004, 08:59 PM   #16
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Thanks Tom
That's why I hired a guy to hook mine up :-)
Still I hope I got the point across.
Originally Posted by tcwilliams
Tim,
Tom
-Tim
theVAP - Airstream Podcast
Old 08-21-2004, 09:32 PM   #17
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Be careful when hooking up the wire to the 30 amp outlet. I just bought an RV box with 30 amp outlet at HD and it fell apart when I hooked the #10 up and tried to push the wiring into the outlet box to button it up. Not sure if any of the commerically available outlets would take a #6 or #8 wire, #10 was tough enough.
The previous owner of my new house had installed an RV electrical line out to the water well pump, and also installed a cleanout in the septic line, so we also have a dump station too!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Interesting connection to Wally Byam found in Revcon motorhome RichardT Airstream History 22 06-22-2010 05:57 PM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 08:10 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
powerlines, 30amp vrs 50 amp skip Electrical - Systems, Generators, Batteries & Solar 21 01-23-2004 12:31 AM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 06:12 PM
