Old 10-26-2015, 10:16 AM   #1
2013 25' FB Flying Cloud
2017 27' Flying Cloud
Orleans , Ontario
30 Amp breaker tripping
On my last weekend camping, there was an occasional smoldering smell and, what seemed unrelated, the main 30 Amp breaker tripped. Thinking the smell was coming from outside and the tripping was not related, simply re-set the breaker. The breaker tripped once more overnight and againth e next day.I called the service department where i bought my 2013 25' FC, and was asked if I heard the fan under the bed running. As I did not, it was concluded that my cooling fan might be not functioning. Can someone help describing how to diagnose this for sure and how to possibly change it out, and where to get a replacement.Thanks
Bryker is offline   Reply With Quote
Old 10-26-2015, 10:31 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Just a guess on my part, but IMHO something else is up beside or other than an overheated converter or inverter.
It takes a lot to trip a 30 amp breaker, unless you are running two air conditioners at the same time, or the air conditioner and the microwave, or a couple or three space heaters.
What loads were you running when the breaker tripped?
Brevi tempore!
J. Morgan is online now   Reply With Quote
Old 10-26-2015, 10:38 AM   #3
Orleans , Ontario
I was only running the electric water heater and at night a space heater. Fridge of course as well.
Old 10-26-2015, 10:43 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The cooling fan under the bed that you are referring to is the little fan that cools the converter when it gets to a certain temperature. This fan does not run constantly. It cuts on and off as necessary.
The fact that you don't hear this fan running, doesn't necessarily mean anything. The dealer telling you that would make me suspicious of his competence.
Tell us more about what was going on when the main circuit breaker tripped. Ours trips regularly when we have too much electrical draw. This usually occurs when we are running the electric water heater and microwave, and the air conditioner cycles on.
As far the burning electrical smell, the first thing that I would check is the relay on the electric side of the water heater.
Brian
SuEllyn & Brian McCabe
Old 10-26-2015, 10:50 AM   #5
moosetags's Avatar
Depending on the amperage draw of the space heater, I would venture a guess that this could be the issue. Some electric space heaters have quite a draw. This coupled with the water heater cycling on and the refrigerator and converter running, could be the cause of your problem. RV water heaters cycle so quickly that there is no real need to leave them on overnight.
We never leave our water heater on overnight or if we are gone from the trailer. I just don't trust them.
Brian
Old 10-26-2015, 10:52 AM   #6
Orleans , Ontario
The AC was not on at the time. Only the regular appliances, such as the fridge, water heater, and at night the space heater. I have used that space heater in the past and had no issues. At some point I did turn the water heater over to propane, as i wanted to "lighten" the load on the electrical system, but the breaker tripped after that as well. The area in around the breaker panel was extremely hot, which doe lead me to believe that the cooling fan may not be working properly.
Old 10-26-2015, 10:57 AM   #7
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
The AMP draw should be listed on the back of the space heater. It is not uncommon for them to draw 25+ Amps.
I like the oil filled radiator style heaters. Just check the amp draw before you buy them.
http://www.tractorsupply.com/tsc/pro...t__d_m_v__vi__
Silverflames is offline   Reply With Quote
Old 10-26-2015, 11:12 AM   #8
Orleans , Ontario
Duraflame Oil-Filled Radiator - For Life Out Here
I will check and see what my heater draws. However, I would think if it draws 25 Amps (or anything over 15 Amps), it should be the breaker for the circuit in which it is pluged into that trips and not the main breaker. I do understrand that the main breaker would ceratianly trip if the Amperage goes above, i.e. when watrer heater cycles on etc, but a 25 amp heater on a 15 amp circuit should wor at all.
Old 10-26-2015, 11:18 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
"Extremely hot" is never good when it comes to electric service. To me it signifies a very real possibility that something else is up beside you just using too many amps.
I suspect a loose connection between the trailer plug and the breaker box.
This heat may have degraded the insulation on the wires at this point.
If it was me I would disconnect all power to the trailer, make sure the inverter is OFF, (all 120 V power absolutely off), grab a flashlight, and pull panel covers to look for what has gotten hot and the damage the heat caused.
Brevi tempore!
Old 10-26-2015, 11:18 AM   #10
2012 30' Classic
Homosassa , Florida
When we had our 25' FC we tripped the breaker frequently until I learned how to better manage the loads. Fridge heats to circulate the cooling for fridge. I don't know the amps it pulls but it takes juice to work. Converter will cycle on and off to keep the 12v lights and batteries going. Space heater probably pulls several amps. Any fans, hair dryer, water heater, phone chargers, TV, Blu ray player or anything else that plugs in will count toward the 30 amps.
Tater is offline   Reply With Quote
Old 10-26-2015, 11:41 AM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Some campgrounds have inadequate wiring to their power pedestals for the loads modern RV's are demanding, so what seems like normal equipment running inside your Airstream it may be causing a voltage drop to your Airstream. That will increase current flow and may well lead to tripping the 30 amp breaker. We keep a simple plug-in voltmeter on our system all the time and turning on an electric heater or cooking device will often bring the voltage down to the red warning zone.
You may think you're not using much power with the appliances you have turned on, but I think you would be surprised. The water heater and an electric heater, added to the converter/charger, plus refrigerator may put you at the limit of the 30 amp system.
The easy solution is to only turn on the water heater electric portion when other things are not needed, it last a long time and recycles quickly. Then turn it off, no need to have it on overnight or much of the day. Or use the gas to heat water. Similar with other big electric draw items, it using an electric cooking griddle, turn off the space heater until you're done, for example.
And I would recommend the plug-in voltmeter as an easy way to tell when you've got more appliances going than the campground power can provide. If it drops into the red zone, turn something off.
Doug and Cheryl
Old 10-27-2015, 09:21 AM   #12
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I recall having a similar issue - my 30-amp breaker was tripping for no apparent reason. It was suggested that I install a new 30-amp breaker. I did so, and the issue stopped. It seems that the bi-metallic strip properties may change slightly as well as the points of contact between the breaker and the panel may have corrosion. Corrosion will introduce some resistance, and the current flowing through will cause that point to heat up. This has also occurred in the 12 VDC system in my AS - JC replaced that breaker as well.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 10-27-2015, 09:41 AM   #13
1974 Argosy 20
Kooskia , Idaho
Absolutely no 120 volt plug in heater draws 25 + amps.
They are limited to the cord and plug capacity of the heater, which is further limited by various codes. The maximum they ever draw is 12 amps.
12 amps x 120 volts = 1440 watts.
Old 10-27-2015, 11:04 AM   #14
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
We only turn on the water heater when we need hot water, even our ancient system takes only 15 to 20 minutes to give us literally burning hot water, plus it lasts a while. Why would anyone leave it on all day? *scratches head* It's an awful waste of electricity or propane.
Dysfunctional Veteran- does not always play well with others. 19 a day is 19 TOO MANY.
(19 recently revised from 20, revised from 23, revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Over heated 20 amp AC breaker tripping woppa 4 Furnaces, Heaters, Fireplaces & Air Conditioning 18 05-21-2009 08:05 AM
a/c tripping breaker? rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 13 08-01-2006 02:59 PM
15K BTU Dometic A/C tripping breaker silverback Furnaces, Heaters, Fireplaces & Air Conditioning 48 07-11-2006 09:14 AM
AC breaker keeps tripping bmimken Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-11-2006 08:57 AM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
