Old 05-28-2002, 09:43 AM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Question 30 amp box
I am considering putting in a 30 amp elec. box so that I can run the AC when visitors overflow at the house. Can this box be mounted on an inside panelled wall in my garage or should it be mounted on the outside of the garage brick? While I know that an electrician should do this, does it entail anything more than running the correct size wire from the fuze box, up the wall, across the garage attic, down the panelled wall and to the new breaker box? Craig
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-28-2002, 10:21 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
If someone else does not reply to this with the correct answer, I will in a day or so. I have acquired 2 30 amp RV hookup boxes that each came with 150' of heavy cable. These were used at a church here in town for traveling evangelist and they no longer supply this service or used the hookups.
I have my favorite electrician coming by any minute to see if I can pull this cable to my service panel. I plan to put these hookups and either side of my house so that I can store my TT on one side or load/service it on the other. Want him to assure me that these will pass code.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 05-28-2002, 10:55 AM   #3
davidz71's Avatar
1986 25' Sovereign
Thanks Bobby.
Craig
AIR #0078
3.73 rear end
Old 05-28-2002, 11:03 AM   #4
Craig. An exterior box is Ok as long as it is intended for exterior use. Running that much wire, as you described, I would make sure that you use an adequate size wire, probably 8 gauge if not 6 gauge. It's a function of total length. Andy
Old 05-28-2002, 02:50 PM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have done this and it is eaisy> Like andy said use the right type of wire and but NAME BRAND components. Leviton, etc. The cheap outlets will berak and then you have a loose connection.
I love being able to fire up the AC while I am working in the coach under the Florida sun.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 05-28-2002, 03:58 PM   #6
davidz71's Avatar
1986 25' Sovereign
Thanks Andy and Brett. Bobby, let me know how your installation turns out and the type of wire (gauge and length) you run. Craig
Craig
AIR #0078
3.73 rear end
Old 09-29-2005, 08:50 AM   #7
Adding an Rv electrical outlet
Adding a remote RV outlet is very easy with some planning. Things to be considered in the plan are, amps of new circuit, new circuit breaker box and RV receptacle, length of new wire run, and location of out door equipment.
Some breaker boxes and receptacles are indoor or out door. It has to do with rain tite. Usually if a new electrical run is greater than 50 feet, a new circuit breaker must be added to the power source box. The power should be able to be controlled at the power source and at the user location. If possible, out door equipment should be protested by location or an enclosure. Collect all the information with a drawing and any special circumstances and talk to an electrical contractor or an electrical supply store. The electrical power needed is 30 amps at 120 volts AC. This requirement would indicate the use of AWG #10. A wire run over about 80 feet would indicate the next wire size larger, that would be AWG #8. I certain areas, the wiring may need to be in conduit of a correct size. Frank
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 10-22-2005, 10:14 PM   #8
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I run My box with AWG #8 and it works great
alfalsetto is offline   Reply With Quote
Old 10-22-2005, 10:35 PM   #9
Tinsel Loaf's Avatar
Hammer drill a hole through the brick wall and mount a exterior covered 30 amp outlet. That way it will be a clean job. If you should ever get rid of your Airstream (heaven forbid) you can always change it to a regular 20 amp receptacle.
Tinsel Loaf is offline   Reply With Quote
Old 10-23-2005, 07:06 AM   #10
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I picked up a 30 amp box at Camping World and am now waiting for the electrician who will be working on our new room addition. I'm also going to be running a long run 50 amp circuit to the far end of the house for a point of use water heater for our master bath. These two new circuits look like they will demand a secondary panel as we are reaching capacity on the old one.
At least the run to the outside box will be short as the driveway is on the service side.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 10-23-2005, 09:38 AM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Here is a handy wire size chart:http://www.nwes.com/Wire%20Loss%20Tables.htm
Looks like 65 feet is the limit for a 30 amp circuit with #10 wire.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
30 amp vs. 15 amp plug? 63flyingcloud Electrical - Systems, Generators, Batteries & Solar 7 09-29-2005 12:26 PM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 05:12 PM
30 amp power cord trouble davidz71 Electrical - Systems, Generators, Batteries & Solar 1 03-12-2003 05:29 PM
30 amp outlet john hd Electrical - Systems, Generators, Batteries & Solar 20 02-26-2003 01:54 PM
