Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-13-2002, 05:36 PM   #1
bkpine
Profile:
Images: 13
30 amp or 15 amp / 59 Traveler
What type of electrical service would a 59 traveler have? 30 amp or 15 amp?
bkpine is offline   Reply With Quote
Old 08-13-2002, 06:43 PM   #2
FrankR
Profile:
Trailer needs...wants
An inventory of existing electrical equiptment can give some hint of AC power requirements. If some electrical upgrades are to be made, a 30 amp power cable and 4 circuit subpanel will be very valuable. All the parts required are easily acquired at Home Depot. The special 30 amp RV power cable end and an adapter to 20 amp will be found an most electrical supply stores. Locating the AC box is more handy outside the trailer in a compartment.
Name:	ac box relocated .jpg
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 08-13-2002, 06:47 PM   #3
bkpine
Profile:
Images: 13
Thanks alot. Just got off the phone w/'em.
Old 09-10-2006, 09:19 PM   #4
piratesteve
piratesteve's Avatar
Profile:  1958 18' "Footer"
idyllwild , California
15 or 30 amp
I am doing the samething with our 1958 Traveler. The wire size will dictate the fuse size! If you need more amperage you may be able to add a second circuit if yours has two circuits like mine. But be careful, the circuit protection should be sized no larger than the wire.
I have included a couple of pictures of our (new to us) Traveler.
Steve
Name:	1958 Airstream Traveler 001.jpg
ID:	25800  Click image for larger version
Name:	1958 Airstream Traveler 018.jpg
piratesteve is offline   Reply With Quote
Old 09-10-2006, 10:18 PM   #5
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
Nice Tow Vehicle!
Better beef up the rockguard- those Fordson's can really throw the terra!
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 09-12-2006, 10:24 AM   #6
piratesteve
Rocks etc.
Sorry Cream Puff that is a 1952 Ford 8N. I looked fro a long time to find one of these of this year because I was born in 1952 and only a 1952 would do!
Steve
Old 09-12-2006, 11:12 AM   #7
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I need to update my panel. I plan to add an air conditioner.
Anything special I should look for in a panel?
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 09-13-2006, 10:32 AM   #8
piratesteve
Air Conditioning
Tim,
I am planning to update the electrical circuit protection on my 1958 Traveler. I will be using ABYC standards when I update what I have.
The Main Circuit protection will be a Circuit Breaker that is Double Pole and there will be a Polarity Indicator. The Trailer already had two seperate circuits, I think that it is basically left and right. The old screw in fuses are cool to see as original equipment but they need to be better protected from gear, etc. if I keep them.
Hope this helps.
Steve
Old 09-13-2006, 01:23 PM   #9
markdoane
Profile:  , Minnesota
Images: 59
Steve,
If you are using a double pole main, does that mean you are running the neutral through the other pole. Excellent!
Non-contributing deadbeat.
Old 09-13-2006, 07:04 PM   #10
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Originally Posted by markdoane
Steve,
please explain, why would you want the neutral interuptable?
john
you call them ferrets, i call them weasels.
Old 09-13-2006, 09:27 PM   #11
piratesteve
The standard on yachts (and what are trailers) is to have a double pole breaker. This is so that both the hot and the nuetral are switched. It makes the trailer safer. If you have a polarity light then you would know if there is reversed polarity BEFORE you turn the power on to the trailer. The polarity indicator is simply a light that shows proper or reversed polarity. This would keep us from shorting something out when at a questionable site or someone made a mistake when wiring the power recepticale,
Steve
Old 09-13-2006, 09:29 PM   #12
markdoane
Images: 59
john
(errata: my post was meant to be a query, but I neglected to add the question mark.)
If you use double pole breakers, wire the hot to one side and neutral to the other side, you don't need to worry about reversed polarity.
(edit: I guess that says the same thing Steve just said)
Old 09-14-2006, 10:10 AM   #13
piratesteve
You do need to worry about reversed polarity. There is a test plug that is available at most hardware stores that checks the polarity. The Hot, Nuetral and Ground wires are assigned to specific terminals on the plugs and recepticales. Since the Nuetral is usually grounded it is important to keep the wires on the proper terminals.
If you are wired correctly and come to a Camp site that has reversed polarity, there could be problems. This is why I believe there should be a double pole and a polarity indicator (light). Look at the Main Breaker for your House, it is a Double Pole Brealer.
Steve
Old 09-14-2006, 12:26 PM   #14
markdoane
Images: 59
Originally Posted by piratesteve
. . . . Look at the Main Breaker for your House, it is a Double Pole Brealer.
Steve
That right, but in your house the reason and application is entirely different than a boat or trailer.
In the house you are dealing with two hots, 240V and a common trip. In a marine/trailer situation, the problem is protection against incorrect wiring due to reversed hot and neutral at 120V.
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 10:38 AM
30 amp vs. 15 amp plug? 63flyingcloud Electrical - Systems, Generators, Batteries & Solar 7 09-29-2005 01:26 PM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 06:12 PM
30 amp outlet john hd Electrical - Systems, Generators, Batteries & Solar 20 02-26-2003 02:54 PM
59 Traveler bkpine 1959 Traveler 8 11-11-2002 11:31 PM
test
