Old 01-09-2015, 06:22 AM   #21
Skater's Avatar
1995 30' Excella
Bowie , Maryland
To answer the original question, there are ones like this from the car audio world.
But you'll note they usually have an input of (for example) 0 or 1 gauge, and an output of 4/8 gauge. There's a good electrical reason for that. The current capacity of two 8-gauge wires would clearly exceed the capacity of one 8-gauge wire, so the 'source' wire or the wire that's going to be carrying more current should be larger.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-09-2015, 07:09 AM   #22
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Wiring
Lots of good advice here, and I would add, liquid insulation can be helpful, then wrap with good electrical tape. Also, heat shrink material can be purchased as a tape for those situations where one cannot access the end of a wire,i.e., something in situ.
I like to use AWG 8, for a main feed line, then wrap AWG 14 around this and solder, for my connections. This results in a mechanically strong connection. Also, when running feeder lines, pull a foot of slack and make certain this relieves any stress on the feed lines. Nothing worse than having taught electrical wires.
I learned long ago, on vehicles subject to the rigors of road and off road bumps and bruises, heavy wiring, sturdy connections are essential for reliability. And, most of us do not want a failure on the road.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-09-2015, 07:32 AM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Marine grade connections....
Just what I do.....
I've learned over the years that for small gauge wiring exposed to the elements it's best to use 'marine grade shrink wrap connectors' then covering it entirely shrink tubing. I do not solder these because I've found that the stiff soldered connection can fatigue over time.
Old 01-09-2015, 08:51 AM   #24
dznf0g's Avatar
Oswego , Illinois
Originally Posted by ROBERT CROSS View Post
Just what I do.....
I agree with Bob, in this case. The shrink/glue sealed terminals are great...and if you try and solder these, the excess head ruins the heat shrink material.
-Rich-
12v
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 09:18 PM
P30 fuse blocks and connectors bkahler Mechanics Corner - Engines, Transmission & More... 6 06-08-2007 08:10 AM
240 volt connectors??? gparker Electrical - Systems, Generators, Batteries & Solar 4 07-31-2006 05:57 PM
12vDC wall connectors walter1 Electrical - Systems, Generators, Batteries & Solar 10 09-19-2004 01:53 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
