Old 05-18-2005, 05:05 PM   #1
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
2nd Battery/7-way connector
Is it possible to add a 2nd battery to my 2002 22' CCD through the 7-way connector at the front of the trailer? I'd like to simply buy a 7-way plug like the one on the tow vehicle, attach that to the new battery pos. and neg. terminals, place a 20a fuse in the positive line, and plug that into the AS 7-way connector. Then, when dry camping, I can place the 2nd battery on the ground and plug it in. Isn't this just the same as providing dc like the charge line does from the tow vehicle?
I've got a 120w watt solar panel which, I hope, will then charge both batteries. This seems much simpler than welding a new bracket for two batteries onto the AS tongue, which would be required to add a 2nd battery to the trailer.
Has anyone added a battery this way? Let me know what you think.
wbrownrr is offline   Reply With Quote
Old 05-18-2005, 05:11 PM   #2
Images: 59
That sounds like it would work, but you should add a knife switch to your existing battery. Otherwise the 2nd battery will go dead trying to charge the first battery.
You can use a battery isolator if you can get enough voltage out of the solar panel. The isolator will cost you about a half a volt.
Old 05-18-2005, 05:16 PM   #3
wbrownrr's Avatar
Why would I need the knife switch? Wouldn't the batteries be wired in parallel, with both charging and discharging at the same rate?
Old 05-18-2005, 05:19 PM   #4
Images: 59
If you always have them parallel, and they are the same construction, that's true. But you will be using the first battery while on the road, or at rest stops, so it will always have less charge than the 2nd battery.
So when you get to your campsite and unload the 2nd battery and plug it in, it will have a higher charge and try to equalize with the first battery.
It could work, as long as you are aware of the limitations.
Old 05-18-2005, 05:29 PM   #5
wbrownrr's Avatar
I see your point. But, the first battery will charge while on the road, either through the solar charger, the T/V charge line, or both. So, actually, the second battery will sometimes have LESS charge. This will probably shorten the life of both batteries. I'm curious if anyone has tried this before.
Old 05-18-2005, 06:26 PM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Send a message via Skype™ to uwe
I would opt for the bracket modification, and have identical batteries mounted to the coach. I imagine you would soon tire of dragging the battery in and out, and making the connections etc.etc.
In addition, the 7-way plug can not transfer high amperage currents, which might want to flow when yor coach battery is depleted and you hook up the second battery, especially when 12V items are running inside the trailer.
A better way to connect a second battery temporarily would be a welding connector and some 6G battery cable.
The danger would be to potentially burn up your trailer connector, causing undue repairs, and a ruined camping trip.
Uwe
www.area63productions.com
uwe is offline   Reply With Quote
Old 05-19-2005, 02:49 PM   #7
wbrownrr's Avatar
Thanks for the feedback.... I'm beginning to wonder if it was such a good idea after all. I'm most concerned about the differences in usage/charging between the two batteries. If I put a 20amp fuse in the connection, I could pretty much avoid any damage to the connector/pigtail... However, I can't help but wonder how much the life of both batteries would be shortened because they would sometimes be at different levels of charge.
Old 05-19-2005, 02:52 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
You know as I read this post, I was thinking exactly what Uwe had said, then I read Uwe's post.
I agree 110% with Uwe's comments.
Old 05-19-2005, 05:22 PM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
wbrownrr
if you really really want to do this go find some heavy welding cable, something like 2/0. and a forklift quick disconnect.
wire the two batteries directly in parallel with the quick disconnect, leaving your umbilical cord out of the picture!
when you pull the plug on the spare you can just leave the connector on the tounge of the trailer. secured of course!
automotive electrical or snowplow suppliers should have the parts you need.
john
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 12:31 PM
CCD 2nd excursion ChrisAich 2002 - 2005 International 18 07-29-2003 04:34 PM
Connector Diagram at AIRSTREAM smily Brakes & Brake Controllers 0 09-10-2002 08:02 AM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 12:48 PM
New City Water Connection j54mark Fresh Water Systems 5 07-01-2002 07:03 AM
