Old 08-16-2012, 06:02 PM   #1
Shawna Bug
Sswest81's Avatar
1991 34' Limited
2nd AC
Just curious if anyone has successfully added a second a/c to their trailer. If so, what electrical changes did you make, did you use existing wires, was it costly? We are thinking of adding a/c in bedroom.
Sswest81 is offline   Reply With Quote
Old 08-16-2012, 06:40 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Without a 6.5 kw gen set, two roof airs would require 50 amp service, that's prolly why the PO bailed on the the second one. I'd say "costly", huge, big time.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-16-2012, 06:45 PM   #3
Central , Mississippi
I added a second air...
I didn't rewire the trailer for it, simply added a 20A extra inlet and another small breaker box...would I do it the same way again? YES!
http://www.airforums.com/forums/f205...tml#post839907
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-16-2012, 06:54 PM   #4
Mike Leary's Avatar
Images: 11
What I was getting at was cutting a hole in the coach, buying the pan and the AC, having the ac installed, running the drain tube to daylight, running wiring to the new panel could be cost prohibitive, except for you high rollers.
Old 08-16-2012, 08:01 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Sswest81 View Post
Just curious if anyone has successfully added a second a/c to their trailer...
This is what I did on the '78 - starting at post 81.
http://www.airforums.com/forums/f219...ign-14737.html
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-16-2012, 08:04 PM   #6
Originally Posted by Mike Leary
What I was getting at was ...could be cost prohibitive, except for you high rollers.
LOL! Man that's great!
I'm saving up to upgrade to a classic MH and joint the Big Bucks Club...
Old 08-17-2012, 10:22 AM   #7
Shawna Bug
Sswest81's Avatar
1991 34' Limited
Very helpful! You all have given me something to think about. We live in Texas and it seems like a second a/c is necessary. Now for the install!
« fridge | Top | Univolt? »
