Old 10-05-2019, 02:30 PM   #1
2014 27' FB Eddie Bauer
Petaluma , California
27FB Eddie Bauer
I am getting a 2014 27 Fb Eddie Bauer, I have been trying to find out if they come prewired for solar, and what exactly the means. Newbie to this.
fireleu6169 is offline   Reply With Quote
Old 10-05-2019, 04:57 PM   #2
2013 25' International
Boise , Idaho
Solar pre-wire
Welcome to the forum!
As you'll see in other posts, there is an astonishing amount of information available in airforums. I've read it every day for a few years and keep learning things. Given this fact, getting to know how to effectively search the forums is worth the effort. I tend to search directly from google - here is an example. The airforums search itself is powered by google, so you can't go wrong - you'll find what you need.
Best,
Adam
afk314 is offline   Reply With Quote
Old 10-05-2019, 11:37 PM   #3
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I have a 2012 Eddie Bauer 27FB. Yes they are prewired, at least mine was, kind of... one end was under the curb side nightstand, the other end is somewhere in the bathroom wall right in front of the mirror. I found the wire went through the space behind the converter and spliced into it there then ran under the floor to the water pump then behind the fridge to the roof. Hopefully yours will go all the way to the roof. The manual says it should be rear of the front vent.
sheriff1 is offline   Reply With Quote
Picture of an Eddie Bauer on the back cover of a semi annual Eddie Bauer flyer BassCan Airstream "In the News" 0 06-18-2016 08:11 PM
25 FB Eddie Bauer :: 2012 Airstream Eddie Bauer Jennybeth Airstream Registry Discussions 0 09-26-2013 06:28 PM
Airstream Eddie Bauer 27FB used 2013/Camper Clinic II eBay Watch Airstreams on eBay 0 01-13-2013 10:30 AM
Airstream Eddie Bauer 27FB used 2013/Camper Clinic II eBay Watch Airstreams on eBay 0 12-27-2012 10:00 AM
Eddie Bauer :: 2012 Airstream Eddie Bauer 25' FB screamstream Airstream Registry Discussions 3 12-12-2011 03:00 PM
