Old 09-20-2013, 05:31 PM   #1
ModernVista's Avatar
2016 28' International
Los Angeles , California
2013 20' FC Sudden Loss of Power to Stereo - Solved
Hey -
i have a 2013 FC 20' that is just over a year old. Last trip the Sony Amp suddenly stopped working. I did a bit of troubleshooting on the road and deduced there was no power to that area at all.
Once back home, i resolved to look at it. i realize i am under warranty, but have already modified some electrical on the vehicle and was concerned that it was something i had done
I had some time today so I checked the wiring from the Sony down through the trailer 12V distribution panel. Ground was fine, but i had no continuity in the positive. i traced it here and there checking along the way. side note: sure wish i had an electrical schematic: i didnt receive on in my manual and there isn't anything that i can find online.
Anyway, this is what i found: Click image for larger version
ID:	196035Click image for larger version
So now i'm a bit flummoxed - is that glue they put on? what is going on?
Clearly there is some corrossion, but i dont see any water damage anywhere. it's all very odd.
i'll clean it up and ensure things are tight for the next trip, but ultimately I want to fix this and since it's my trailer i'm tempted to just splice the two together, or use a new Packard connector. Anyone know what this is?
cheers
Chris
ModernVista is offline   Reply With Quote
Old 09-20-2013, 06:42 PM   #2
I took a closer look - and that white gunk must have been some sealant they used [pipe sealant?] it was thick and wouldnt allow the connector to click closed. i cleaned it out with a metal pick on both ends and it looked good as new. definitely wasnt water damage or anything.
clicked closed, case solved.
cb
Old 09-20-2013, 11:55 PM   #3
mefly2's Avatar
2015 25' FB Eddie Bauer
If you are worried about corrosion ... try putting a bit of dielectric grease (inexpensive and available at most hardware stores) on the connections / plugs.
Old 09-21-2013, 12:22 AM   #4
1974 Argosy 20
Kooskia , Idaho
very strange, very. Why would any sealant be used there?
I also have done a lot of electrical mods to my new 20'. Tri metric meter, Progressive Dynamics converter/charger, my own solar system, switches for other things. I could not wait for the warrantee to expire, had to do them ... ya know.
