09-07-2006, 11:59 PM
2005 25' International CCD
redlands
2005 CCD electrical issues
We just started having trouble with our 1 year old 25" CCD international trailer. When we got to our last destination we found the fridge, water heater, stove vent fan and galley lights ( all on one circut) would not work. there was a blown fuse noted in the circut for the furnace but the fuse for fridge etc was intact.
we replaced a dead battery and the fuse and things started working again, but only for a day. same thing happened after about 12 hours, fridge out waterheater etc.
in my gut i think the converter may be bad. not sure though. we had the dealer put in a solar panal and i dont things have been right since then????
thanks for any help.
11-30-2006, 10:19 PM
1960 18' "Footer"
Riverside
ablaze, saw your question on your battery in your 2005 25' CCD not charging. Did you ever get it taken care of? I would think that your dealer left a wire from the converter off or you may have the battery disconnect switched off when connected to shore power.
We have the same trailer, the batteries didn't stay upas well as those in the previous 22'CCD we had but we bought it one year old, it's now two years old so I replaced the batteries with gell and installed 2 130 watt panels on the roof.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
12-01-2006, 06:45 AM
2001 34' Limited
The State of
If you have an anti-sweat (condensation) feature on your refrigerator, and it's turned on, it can drain a battery pretty quickly. It's typically an internal 12 volt heating element around the door frame.
Maurice
10-29-2007, 01:46 PM
2012 30' International
Pleasant Hill
, The Golden State
Sorry you are having electrical problems. Our 2005 CCD had a failure of the converter/charger early on. Replaced under warranty and no problems since.
That is the first component I would check. We actually noticed the lack of the usual hum (fan) about the same time we noticed batteries running down while hooked up to shore power.
Good luck.
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
10-29-2007, 01:48 PM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Good luck.
That thread is from 06. However, I'd stilll ike to know how the problem got resolved.
10-29-2007, 04:25 PM
Shreveport
, Louisiana
oddly enough, this was the 2005 25' CCD that was totaled in July ( http://www.airforums.com/forums/f48/our-loss-35568.html)
However, the problem was resolved (at the time) with purchasing a new battery. No problems after that.
10-29-2007, 04:28 PM
418
1974 29' Ambassador
Yucca Valley
Originally Posted by gardenofjoy
Small world, aahh, ...forum. I read about your misfortune earlier today. What a complete disaster. Glad you're here to talk about it, though.
10-29-2007, 05:57 PM
2007 23' International CCD
Lapeer
, Michigan
Did you only replace one battery of 2? Perhaps the bad cell affected the other battery and now that you have a new battery the affected battery is wearing down the other? We went through that with our 2005. Had to replace both batteries together, tried one at first and the batteries did not stay up for long.
Right now the 2007 batteries are showing full but plunging immediately under a load. We have AGMs being sent to us along with a Xantrex battery monitor and converter upgrade kit to make the Parallex a three stage converter. These we have on order from Randy at bestconverter.com He has been very helpful with our questions and concerns.
BestConverter - Inteli-Power, WFCO, Parallax, Xantrex, Samlex, Electrical Supplies
