Old 09-17-2017, 08:36 PM   #21
dasams's Avatar
Palm Desert , California
Originally Posted by capt_ron777 View Post
Main is 15000 and rear 13500. Another question. Who makes Easy start and how and who needs to install it? Thanks
Put it on the smaller unit and it'll work great at sea level. If you go up in the mountains, the power output will fall and it may or may not work. We were at 3,500 ft in Oregon for the Great Eclipse and our Honda 2000 would not run our 15,000 btu AC. But it worked great at sea level.
Google Easy Start for info and it's a DIY if you are comfortable reading simple wiring diagrams. Otherwise see the service dept at your local RV dealer.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 09-19-2017, 06:11 PM   #22
2018 27' International
carbondale , Colorado
Another question from a newbie.I'd like convert a yamaha 2400 gen to propane and hopefully use the 2 tanks on my AS. The us carb site asks if they are a high pressure system or a low pressure. I think if they're tanks than they are high pressure. but somewhere I read many rv's step this down internally already to a low pressure system. Anyone know which it is?. Alot to learn here, but it sure is fun.
capt_ron777 is offline   Reply With Quote
Old 09-19-2017, 06:30 PM   #23
2011 22' Sport
Portland , Oregon
It really depends on how you want to connect them, and if your particular year/model of trailer has factory an installed propane quick disconnect for accessories or not. I have a 2011 22FB, it did not get this from the factory but i will be adding a quick disconnect myself.
If you are using a quick disconnect then it is on the low pressure side of the auto-switchover regulator. The other option is that you would unscrew the regulator from one of your propane bottles, then you would need a high-pressure regulator to go from tank pressure to the generator.
(edit and noticing you have a a '17 Flying Cloud 26', which almost surely has a propane quick disconnect up under the A-frame)
SilverHouseDreams is offline   Reply With Quote
6 months with the AIMS 2000 Watt Pure Sine Inverter Charger trekerboy Batteries, Univolts, Converters & Inverters 9 07-10-2017 08:17 AM
Suggestions on Upgrading stock coach batteries to 400 Watt from stock 160 Watt odonnell71 Sprinter and B-van Forum 5 05-07-2017 08:59 AM
Generac iX 2000 Watt Portable Inverter Generator Frank&Mike Generators & Solar Power 21 11-06-2014 07:20 PM
Question on Yamaha EF2400iSHC - 2000 Watt Inverter Generator. Ditter Generators & Solar Power 22 02-19-2013 07:31 PM
2000 watt Cen-tech Inverter On Sale TinCanW/6 Full-Timing, Winter Living & Workamping 7 01-08-2013 08:53 PM
