Old 01-21-2008, 06:13 AM   #1
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
20 Amp or 30 Amp, that's the question
Here's one for the experts to noodle out. The main circuit breaker coming into the 110v panel from the shore power is only a 20 amp breaker. Coming out of the panel there are two 20 amp breakers that feed the interior of the camper. One of these 20 amp branch circuits feeds the air conditioner. The other 20 amp branch circuit feeds all of the other 110v outlets.
So the question is, why only a 20 amp for the main, shouldn't it be a 30 amp? Is there any reason why I can't replace it with a 30 amp?
The shop manual isn't much help here. The wiring diagram in the manual shows the circuit layout to be exactly what I have (wiring only). The diagram of the breaker panel (panel only)shows only 2 20 amp breakers, one to the shore power and one to everything else inside the camper (obviously this isn't correct).
As always, thanks for the help!
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 01-21-2008, 06:17 AM   #2
. , At Large
the reason for this is because the air conditioner is completely separate from the rest of the wires. The wiring in the trailer is only supposed to be able to handle 20 amps.
Old 01-21-2008, 06:23 AM   #3
I understand that part of it; the air conditioner should have its own dedicated circuit from the panel. What I don't understand is why the shore power breaker is only 20 amp. If the camper is supposed to be 30 amp, why wouldn't the main breaker be a 30 amp? The mystery continues....
www.nesa.org
Air No. 6427
Old 01-21-2008, 06:26 AM   #4
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
My trailer is the same; however, we had an additional plug installed on the AC circuit for use in the winter. Since we have the elect/LP water heater on the other circuit, we were limited in our use of the 20amps. In the winter we use the AC circuit for an electric heater. We have not put in a new furnace and have been hesitant about using the original central heat in the Argosy. Actually we don't use the trailer much in the really cold part of our winters, so with the cat heater and the electric space heater this has worked out well.
juel is offline   Reply With Quote
Old 01-21-2008, 06:32 AM   #5
Naples , Florida
Jim,
Look at the guage of the wire that is feeding the breaker box from the street connection. The breaker on that lead should the wire guage.....20 amp for 12 guage and 30 amp for 10 guage.
lewster
Old 01-21-2008, 06:42 AM   #6
I just went out and checked, the street connection is 10 guage and printed on the wire it reads "30 amp" service. SO that means that I can replace the 20 amp street side breaker with a 30 amp, right?
www.nesa.org
Air No. 6427
Old 01-21-2008, 07:06 AM   #7
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Our '77 has 10 ga. service wire & 30A main breaker.
The individual circuits are protected at 20A so I (not being an electrician) would feel comfortable changing the main to 30A.
Seems like you should be able to maximize the use of 30A service offered by campsites.
For example:
If you are using the AC (has it's own 20A circuit) and a microwave (let's say 800 watt size) on the receptacle circuit; the 30A main would allow this when the existing 20A may not. right?
Qualified advice is needed here. Amateur electricians can burn things up.
martin.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 01-21-2008, 07:14 AM   #8
Well, I just went back out and looked at things again. Then looked back at the shop manual. Seems things got a little confused here because of a PO's "creative wiring". Let me see if I can explain.
First, there is no "main" breaker facing streetside. The shop manual shows a direct feed from the street to the main buss without a circuit breaker. Then, there are 2 20 amp breakers that feed the two branch circuits described above (one for the air conditioner, one for everything else). This is actually how things are wired in the panel.
Seems a PO rewired things and left an extra 20 amp breaker in there that is not wired to anything.
So I suppose the real question now is, should I rewire the streetside connection so that it actually has a true "main" circuit breaker that can trun the power off coming from the street. Weird.
www.nesa.org
Air No. 6427
Old 01-21-2008, 07:29 AM   #9
empresley's Avatar
1977 Argosy 24
Central , Georgia
Jim,
Considering the age, capacity & limited utilization, I would suggest replacing
with something you can have confidence in.
Try an elec. supply house for a better selection of panels and... I bet you can get a small panel and necessary breakers for under $100. If McDonough doesn't have a large commerical supplier we have several in Macon & I can pick one up for ya.
Old 01-21-2008, 07:38 AM   #10
I think you're probably right, Martin. The idea of not being able to cut main power at the box isn't very appealing. On the other hand, I could just unplug the dang thing!
www.nesa.org
Air No. 6427
Old 01-21-2008, 08:20 AM   #11
Images: 59
If the service cord is connected directly to the buss, and the two 20a circuits are connected to the buss, you should install a 30a main breaker.
If the box has room for another breaker, you would install the 30a breaker on the buss, adjacent to the branch service breakers. Then you connect the hot wire from the service cord to 30a breaker.
It may look unusual. It will look like you are running the power "backwards" through the main breaker. This is how it is done.
Be sure that you have the ground and neutral wires separated. Sometimes a PO, or even a residential electrician, will bond the ground and neutrals together.
Old 01-21-2008, 09:09 AM   #12
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by markdoane
...Sometimes a PO, or even a residential electrician, will bond the ground and neutrals together.
This is exactly what happened about 7 years ago when I developed a short in the 30 amp power cord plug. It kept tripping the campground circuit GFIC so a well meaning factory maintenance electrician ran a jumper wire from ground to neutral. It kept tripping the campground circuit even after I replaced the power cord plug. Once home, I compared the breaker box to the schematics in my manual. Funny thing, there was an extra wire in there that was not there before. I know it was not there prior to this incident because I had replaced a 30 amp main breaker and decided to draw a diagram of the wiring just for the heck of it. Fortunately I kept the drawing and it matched the factory diagram. I removed the jumper and everything worked fine.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-21-2008, 09:09 AM   #13
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I agree with EMPRESLEY on replacing the whole box with a new box. I am goimg to go a step further on my GT resto, and go with a 50 amp box to add a dedicated circut to the electric portion of the new hot water heater, fridge, and the micro wave, along with the air conditioning circut, and then a GFI breaker for all the regular outlets. The hot water heater will also have a GFI breaker. I am a strong believer in the saying "better to have and not need then to need and not have"
Kip
Aerowood is offline   Reply With Quote
Old 01-21-2008, 09:57 AM   #14
. , At Large
The limiting factor in your wiring is the wiring. you can't have more than a 20 amp breaker if the wiring will only handle 20 amps. From the breaker out to the pole the wiring is rated at 30. If you put a 30 amp inside the triler, the 20 amp rated wires will melt before the breaker will trip. The 20 amp main interior breaker is only for the trailer wiring, not the air conditioner, that wiring is completely seperate.
Old 01-21-2008, 11:06 AM   #15
Images: 59
I'm suggesting that you add a 30a main breaker, and leave the two 20a branch breakers as they are. The 30a breaker limits the energy flow into the buss bar, and the two 20a breakers limit the energy flow out to the branch circuits. None of the trailer wiring other than the main 10 ga. service cord would be exposed to 30 amps.
The 10 ga. service cord is protected by the 30a breaker, and the only wiring between the main breaker and the 20a breakers is the buss bar.
Old 01-21-2008, 12:22 PM   #16
. , At Large
That would work, but I think it might be making something unduly complicated, adding another component that would then be able to fail.
Remember, if it ain't there, it can't break.
Old 01-21-2008, 01:09 PM   #17
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Am I confused?
Are you really just going to install a 30 amp breaker in the service line as a "surge protector" for you breaker box? As Terry says... adding that would likely make just one more item to fail! I am confused as to what was said concerning a separate power source for the AC in your wiring. I have two 20 amp breakers in my box one for the AC and on for the 110 volt outlets. Is this what was meant by separate wiring? Also any power coming off the 20 amp breaker is on household 20 amp 12 gauge wire right? This is a standard way to wire an air conditioner (on its own circuit). If you were to run a third wiring source off a third 20 amp breaker for water heater/heater power there will have to be all new circuit wiring running to those items unless you can separate the circuit wiring at your terminal board. Is this not correct? I have an electrician who will be making all my final connections in my trailer but I would like to know ahead of time that I understand the way things should be. Someone please correct me if I'm wrong or misunderstand how the wiring is in these trailers. Happy Trails, Ed
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
BIGED52 is offline   Reply With Quote
Old 01-21-2008, 02:04 PM   #18
Images: 59
It might be added complexity, but the code sometimes requires things for safety and this is one of them.
I understand that some early Airstreams may have had separate power connections for air conditioners. That was before 30a supply stands were common.
The current code (NEC 551.42 (C)) requires any unit with two to five, 15- or 20-ampere branch circuits to have a distribution panelboard rated at 120volts maximum with a 30-ampere rated main power supply assembly.
Without a thirty amp main breaker, it is possible to be pulling 40 amps (2x20amps) through the 30a rated service cord.
While most RV power stands have 30 breakers to protect the plug, they are not universal, and NEC requires only a disconnect.
Old 01-21-2008, 02:29 PM   #19
Polecat1's Avatar
1979 29' Ambassador
Las Vegas , New Mexico
20 amp?
If your wire into the trailer is #12 or better, it can handle a 30 amp breaker at the street. Each 20 amp breaker in your panel will take what ever it needs. The 30 amp breaker in the street will now be your "MAIN" breaker providing yoiur cord to the trailer is #12 stranded or better which it is I'm sure. I have never seen anything smaller than#10 stranded wire.
Retired electrician.
Ted
Polecat1 is offline   Reply With Quote
Old 01-21-2008, 02:41 PM   #20
Polecat1's Avatar
1979 29' Ambassador
for the moderator::: how do I post my own question on this page. It has to do with removing a broken window? I know this is out of context but I am new and don't know how since there is not a means on this page to submit my own question. Thank you. Ted
Ted
30 / 50 AMP Question kleimanr Electrical - Systems, Generators, Batteries & Solar 7 11-03-2007 02:58 PM
Car & Driver Jan 07, Airstream & Benz Karyn Airstream "In the News" 14 12-04-2006 10:26 PM
Preztels & Beer or Biscotti & Cappuccino? GreggH Community Polls 26 02-20-2006 06:08 PM
Curb Side & Front Glass Window & Clips Oceancontainer 1960 - 1965 Safari 2 07-28-2003 07:04 PM
Dumb Question regarding the bed & sheets kamadeca 2000 - 2004 Safari 8 06-23-2003 02:24 PM
