Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 02-12-2008, 09:15 AM   #57
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Exposed 120V in walls?
Originally Posted by CrawfordGene
Rewired, redone, proper voltage and polarity. Finally an exterior 30 amp receptacle.
That is good news.
You can't just change the plate. They must have changed to one piece 120v receptacles the day they wired my Safari. At least one (bathroom) has the holes drilled for a standard duplex receptacle, but the one piece unit was installed instead. I can take out the one piece units and go to a standard receptacle and use a metal plate that looks better, or forget it. Something to mull about…
Gene
Did you put in standard house recepticals? That leaves exposed 120V in the wall. Dangerous.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 02-12-2008, 10:27 AM   #58
CrawfordGene
Profile:  2008 25' Safari FB SE
Crawford , Colorado
No disaster yet
Michelle, good point. I haven't done anything except replace the one cover plate. With the one piece receptacles, just thinking.
To replace them with standard receptacles, even back wired with the receptacle wrapped in electrical tape, not a good idea since they don't reside in a box (tape will eventually fall off and hot wire could arc to aluminum). I'll have to look at these one piece receptacles and see how they are made and if there's some alternative that will allow me to use metal plates. One would be to use a shallow old work plastic box, but that seems like more trouble than it's worth. The one over the kitchen counter was easy to replace the plate so I didn't pay any attention to that receptacle since the front looked like any other receptacle.
I have an extreme case of electrical aluminitis mixed with not thinking beyond house wiring. I have also thought that I should go through all the hidden places where they have run Romex across sharp edges and see if it's likely to rub the insulation off over time. Once again I'm glad the Forum is here so I can post my crazy ideas and find out if I'm going to have a trailer that glows in the dark.
Gene
CrawfordGene is offline   Reply With Quote
30 / 50 AMP Question kleimanr Electrical - Systems, Generators, Batteries & Solar 7 11-03-2007 03:58 PM
Car & Driver Jan 07, Airstream & Benz Karyn Airstream "In the News" 14 12-04-2006 11:26 PM
Preztels & Beer or Biscotti & Cappuccino? GreggH Community Polls 26 02-20-2006 07:08 PM
Curb Side & Front Glass Window & Clips Oceancontainer 1965 Safari 2 07-28-2003 08:04 PM
Dumb Question regarding the bed & sheets kamadeca 2003 Safari 8 06-23-2003 03:24 PM
test
