Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-26-2014, 08:01 AM   #1
1974 Argosy 26
Cumming , Georgia
2 Titan 6V Batteries- 45amp or 60amp Converter?
In my '74 Argosy 26, I am replacing the Univolt and single 12v 24 series battery with 2 6v Titan t-105's and new converter. The question is, do I get the 60amp or 45 amp converter? I know I will also need a new fuse box, which I will order.
IBArgosy is offline   Reply With Quote
Old 06-26-2014, 09:47 AM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
From the point of view of your converter you're just looking at a 105 amp-hour battery bank, so I think a 45a will do it (and will run off a 1000w generator in a pinch).
If memory serves you never want to charge at more than 25% of the total amp-hour capacity, so for 105 AH that's just over 26A, leaving quite a bit of capacity for trailer loads with a 45A converter.
Now, if you're still running all-incandescent lights in the Argosy you may have enough load with all the lights on to make use of the extra headroom of the 60a when charging and running most of the loads inside the trailer simultaneously.
— David
Nissan Titan n2916s Tow Vehicles 135 12-18-2016 09:51 PM
Univolt to 60amp Powermax two questions Britbat Batteries, Univolts, Converters & Inverters 3 08-03-2014 07:03 AM
Univolt To Power Max Boondock 45amp/New Converter Tony S Batteries, Univolts, Converters & Inverters 5 04-09-2013 05:16 PM
Univolt to Intelligent 60AMP ssolid Electrical - Systems, Generators, Batteries & Solar 4 09-02-2005 07:30 AM
GCVWR for Titan? Big Dee On The Road... 12 03-17-2004 09:59 PM
