Old 02-17-2006, 08:25 PM   #1
1971 27' Overlander
Richmond , Virginia
2 Shore Lines?
Hi Guys!
I am new to this forum, so please forgive me if I am not posting in the right place. I just bought a 1971 Overlander one week ago. I have not been able to spend much time exploring all if its systems yet, but one thing seemed very strange to me. When I raised the rear access panel to hook up the electrical connection (shore line), I found that the trailer had two lines. Is this normal? I did not have enough time to undo any other panels and see what they are connected to, so I figured I would ask the experts! Any insight into this mystery would be gretaly appreciated. Thanks!
Everett
ecomstock is offline   Reply With Quote
Old 02-17-2006, 08:31 PM   #2
RichardT's Avatar
Are you sure it isnt just 1 shore line, and 1 extention cord? I store a long extention cord that looks identical to my shore line and I could see how it would look like two power cords.
RichardT
RichardT is offline   Reply With Quote
Old 02-17-2006, 09:34 PM   #3
Darol Ingalls's Avatar
If it's not just another extension cord, you probably have something modified by a previous owner. Maybe a seperate cord for an electric water heater? space heater? AC? Whatever it is, it most likely was not original equipment since all 120V circuits ran through the breaker panel powered by the main cord. Check it out carefully. Don't burn the trailer down!
Darol Ingalls is offline   Reply With Quote
Old 02-19-2006, 06:25 PM   #4
1971 27' Overlander
Richmond , Virginia
Figured it out
Hi again,
I was able to spend some time with my Airstream today, and I was able to remove some of the access covers inside and outside the trailer. The second shore line that I have stowed away in the rear storage is not connected to anything inside of the trailer after all. I traced all the way to the circuit breaker where it is sitting disconnected. The people who had this Airstream beforehand really did a number on it. I have my work cut out! Thanks for all of the help!
Everett
Old 11-08-2011, 08:40 PM   #5
2009 25' FB Flying Cloud
Portsmouth , Rhode Island
What is the maximum length of shore power line I can run and what gauge should it be? I am looking at 100'. Help, please! Thanks!
Jack
JackRenner is offline   Reply With Quote
Old 11-08-2011, 08:48 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Jack
If you are going that far, my opinion is that you should extend the electrical service closer to the trailer.
I have a 10 ga. 25' extension chord that I use occasionally. It gets hot when I use the AC
Alan
Old 11-08-2011, 09:01 PM   #7
r carl's Avatar
Lin , Ne
Jack
It depends how many amps your going to use in your camper. If you want to use 30 amps of 120v at the end of a 100ft cord you will need 8 guage.
new water lines Rob Fresh Water Systems 29 07-11-2006 09:25 PM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-30-2002 12:02 AM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-06-2002 12:42 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 02:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 07:04 AM
