Old 06-30-2016, 08:39 AM   #1
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
2 Amp Battery Charger
I have a friend that uses one of these low amp (and very low priced) battery chargersClick image for larger version
Name:	ImageUploadedByAirstream Forums1467297496.776633.jpg
ID:	265573 to keep his vacation home's vehicle charged while they are away. It is connected to the car's battery for up to 3 months at a time. The battery stays charged for immediate use when they are using the home. Would this type of charger be ok to leave on my 2015 27' International while it is in storage? My concern is how it might affect the converter.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 06-30-2016, 12:26 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by Pat Cassity View Post
I have a friend that uses one of these low amp (and very low priced) battery chargersAttachment 265573 to keep his vacation home's vehicle charged while they are away. It is connected to the car's battery for up to 3 months at a time. The battery stays charged for immediate use when they are using the home. Would this type of charger be ok to leave on my 2015 27' International while it is in storage? My concern is how it might affect the converter.
It won't affect the converter.
Be sure there is sufficient electrolyte in the batteries, add distilled water if needed, before and after using. A 2A charger will cause some loss of water.
I've never been sure of the fire safety of those things. I had one once on a car I rarely drove, but I added a fuse to the DC side of it.
Magnum MMS1012 1000W Pure sine Wave Inverter w/50 Amp Charger & Remote exallen Airstream Classifieds 0 06-05-2016 03:25 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
Magnetek Series 900 Model 950 50 Amp converter / charger Specs & Features? Driver1 Batteries, Univolts, Converters & Inverters 7 03-29-2008 12:55 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
