Old 10-08-2017, 09:57 AM   #1
1987 25' Sovereign
Blairstown , New Jersey
1987 25' Sovereign. New 120v 30 amp service inlet.
I do not like having the 30 amp cable coming in trough the last frame crossmember below the floor.
I am thinking of installing a 30 amp smart plug in the left (street side) rear panel above the floor and having a short connection to the adjacent junction box.
Has anyone done something similar, as in cutting a new opening in the outer skins?
Thanks.
Robertone139 is offline   Reply With Quote
Old 10-08-2017, 11:56 AM   #2
1979 23' Safari
Wayland , New York
I did it in my 23' Safari. Use hole saws to cut the holes. Look around the area you're cutting to eliminate possibility of drilling through something inside the wall, like wires or ac drain. Drill inside hole first to check for obstacles that way if you have to go to a different spot you can cover the inside hole easily. Measure 5x cut 1x. I made a template out of cardboard and taped it to the outside of the trailer to find a good spot.
sovereign
Carefree Roadside & Rear Window Awning Arms & Rollers For 1976 31' Airstream Sovereign mrnos44 Airstream Classifieds 0 08-23-2016 07:08 PM
Service snafu $&!&& and which battery is which amirm Sprinter and B-van Forum 25 07-04-2016 09:19 PM
Furrion Stainless Steel 30A inlet and TV inlet Gsmblue Electrical - Systems, Generators, Batteries & Solar 4 07-27-2015 06:58 PM
120V 30amp RV trailer electric service: 100' x 8-3 wire jgreager Airstream Classifieds 0 05-18-2015 02:36 PM
New volt/amp meter for 120v Jammer Electrical - Systems, Generators, Batteries & Solar 1 05-18-2014 10:00 AM
