Old 08-10-2004, 08:57 AM   #1
emanon25's Avatar
Question 1972 27' overlander wiring
This trailer has had the original Univolt replaced with the Univolt V. There is no power to the contol panel at the front except when the tow vehicle is connected and running. None of the electrical devices work except the water pump, also only when tow vehicle is running. Fuses are good, including the one on the negative side. There was a poor ground from the shunt to the chassis but that has been corrected.
Qestions: Are there circuit breakers? Where are the circuit breakers located? Where are the switches for the overhead vents. Can someone give me a brief summary of what each of the four fused circuits feed?
Thanks-
emanon
emanon25 is offline   Reply With Quote
hitch wiring question Craig Lights - Interior & Exterior 4 07-18-2004 06:09 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Tailight Wiring '62 Overlander Deppdog Electrical - Systems, Generators, Batteries & Solar 2 07-17-2003 08:53 PM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
