Old 04-22-2014, 12:29 AM   #1
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
1966 28' International Ambassador wiring schematic
Gentlemen,
We recently purchased our first AS. It's a 1966, 28' International Ambassador. Is there a 12v schematic available that shows the routing for exterior wiring from the umbilical to the tail lights ? Also, is there a landing point bus somewhere inside the trailer where the 12v branches from to supply all the exterior lights ? Where is the typical place that the ground wire is located and attached to the frame where the umbilical disapeares in the underbelly ? I'm sorry if my post is in the wrong area. I just saw the "interior/exterior" section under electrical. Administrator, if you move my post, could you please let me know so I can find it in the appropriate area ?
Thankyou very much for your help,
Danny
Danny Bell is offline   Reply With Quote
Old 04-24-2014, 09:51 AM   #2
Rucksta's Avatar
1968 20' Globetrotter
Grants Pass , Oregon
I'm definitely not a wiring expert, so take this with a grain of salt. *Disclaimer*
I have a '68 Globetrotter, so may be similar to yours...
When I recently replaced my 7 way trailer cord I found an access panel in the belly pan (Curb side front). Although access is limited, I was able to find all seven wire terminations... no bus, though.
'68 Globetrotter "Tonto"
Rucksta is offline   Reply With Quote
Old 04-24-2014, 11:56 AM   #3
Originally Posted by Danny Bell View Post
Gentlemen,
Danny
Danny.
There is a small access panel underneath the trailer at the front end.
Removing that cover will expose the wiring connections.
The following colors are for the noted circuits.
white=ground
blue=charge line
red=left turn and brake
brown=right turn and brake
green=clearance and tail lights
yellow=brake
black=back up lights
Wiring Schematic for '68 Ambassador 29? Silver Suckr Electrical - Systems, Generators, Batteries & Solar 1 07-23-2011 11:13 AM
1973 Safari Wiring Schematic gmatteri Member Introductions 1 10-26-2009 06:56 PM
1975 Argosy wiring schematic argosy75 All Argosy Trailers 8 06-09-2008 06:08 PM
Schematic wiring diagram for Armstrong AC TR21-12, GO7series DMC Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-06-2007 12:01 PM
Hello, looking for a schematic of the wiring in my Armstrong AC model TR21-12, DMC Member Introductions 1 07-10-2007 06:11 AM
