Old 04-18-2004, 10:15 PM   #1
1961 - 12 volt or 6 volt?
Need a little help, o' wise sages of great Karma.
Working on my '61 Safari and was wondering if it was 6 volt or 12?
Also, my outside battery box is in bad shape, could I put a sealed (Optima) battery under the dinette seat until I get the box fixed? No real danger is there from a sealed battery?
Marlboro Mafia is offline   Reply With Quote
Old 04-18-2004, 11:37 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Your electrical system is 12 volt unlike early automobiles that had 6 volt. A battery inside the coach is fine if it is sealed. The original battery box will not hold an Optima battery. It houses a farm implement battery. Seach the forums for the kind and part number. BTW, a battery only gives off fumes when being charged.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-19-2004, 07:18 AM   #3
Thanks! I intend to make a new box for the front to fit Optima but until then I may extend wires back into trailer.
What battery do you recommend? Are the sealed ones worth the $$? If I manufacturer a replacement battery box for the front exteror that duplicates the original(except for size) would there be many takers?
Old 04-19-2004, 07:31 AM   #4
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I'm not so sure I would want the extra weight being supported by the wall but you may get some takers. Are you a metal worker? You didn't post your location in your profile. I need a new compartment door cover. If you offer, I will take you up on that
FF
Old 04-19-2004, 09:03 AM   #5
Not a metal worker, just a big enough redneck to think I can do anything once.
The weight should not be too much of an issue since the battery would be winder but not as long.
12 volt, 1961
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
12 volt TV? john hd On The Road... 52 07-02-2008 02:16 PM
1961 Bambi for $1000! yukionna On The Road... 4 06-20-2004 05:26 PM
New 1961 Overlander greg176 1960 - 1964 Overlander 13 06-04-2004 02:21 PM
1961 Caravan project new2me General Repair Forum 3 03-19-2003 08:35 PM
