Old 01-07-2017, 11:39 AM   #1
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Question 15amps
A trailer park only has 15amps for electric, will be there for 5 days, what can I run on 15amps?
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 01-07-2017, 11:57 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
That is enough to run the converter/battery charger to keep your batteries topped up. Your lighting, fridge electronic circuit board and the furnace circuit board run off the batteries. If you want to run something like the microwave, you may need to shut down the converter/charger. Most hair dryers use between 800 and 1800 watts.
For example here is how to calculate the amount of power you have to run all AC appliances:
  • 15A to watts calculation with voltage of 120V AC
  • For AC power supply, watts are equal to the power factor times amps times volts.
  • watts = PF × amps × volts
  • For resistive load without inductors or capacitors, the power factor is equal to 1:
    watts = 1 × 15A × 120V = 1800W
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 01-07-2017, 12:29 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Although the pedestal has a 15 amp breaker on it, voltage and available power (as determined by wire size, length, and the amount of power other campers are drawing on the same campground wiring will vary widely.
Using the 30 amp plug at the pedestal at our present 30 year old campground with original wiring, we have about 116-120 volts depending on the time of day, and other camper loads on the system. We can (usually) run two major heating items at a time, for example the water heater and the space heater. Turn something off to make coffee or there is too much voltage drop for my comfort (110-112 volts).
At the last park we had 124 volts in the Airstream, run three major heating appliances at a time with maybe a drop to 120 volts. Better park wiring and fewer campers, especially the big motorhomes and fifth wheels.
To sum this up, the converter/charger will use most of the 15 amps in many parks, use the propane system for heating/cooking.
Doug and Cheryl
Old 01-07-2017, 02:29 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
You should be able to run everything except your air conditioner(s).
wulfraat is offline   Reply With Quote
Old 01-07-2017, 03:16 PM   #5
Sioux Falls , South Dakota
"You should be able to run everything except your air conditioner(s)." Just not all at once.
15A @ 120 volts = 1800 Watts. My suggestion would be to start with full propane tanks and keep the hot water heater and refrigerator on propane. Leave the converter/charger on and use only one major appliance (microwave, coffee maker, a/c, etc.) at a time. You probably won't need the a/c now, but an electric space heater in the bath might be nice. Don't run any other big draw item when it is on.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 01-07-2017, 03:44 PM   #6
Long Island , New York
Ditto to David, but if you use a small electric heater use the Low setting if you are running other 120 volt items.
Echo: water heater on propane only -- fridge is probably OK on 120 electric IMO.
Have fun! We are having a major snow storm in the NE, so any electric use in an Airstream seems pretty nice right now!
Peter
Old 01-07-2017, 04:07 PM   #7
wulfraat's Avatar
Correct :0)
I omitted that fact because it seemed incredibly obvious. No system (including the 120v 200AMP service in my home and including the Airstream with a 30amp connection) is design to run "everything" (coffee pots, space heaters, microwave, TV, air conditioner, converter, furnace fans, 12v accessories, stereo, battery charger, etc etc) ... at once....
Old 01-07-2017, 06:35 PM   #8
Alluminati's Avatar
St. Louis , Missouri
It is beyond me why everyone so loves their electric space heaters. Does everyone run space heaters all over their house? Where is a safe place to put a space heater in a trailer? Few on this forum have a trailer as large as mine, and there are precious few places to safely keep one running in my rig.
The rest of the world is fooled into thinking our RVs are an indication of discerning taste. Yet we run hazardous little heaters because??? Are we too cheap to use our central heat? If we can't afford the comfort, convenience, and safety of using our LP furnaces, then I seriously question our fitness to own a luxury RV.
To the original OP: You should be able to run anything but your AC on 15 amps. Don't do any ironing while you brew coffee and make toast. Otherwise you should be just fine. 15 amps should be able to run anything but AC.
Back when all our homes had 60 amp service, the lights dimmed at times when everything was on. That's why we upgraded to 100, then 200 amp service so that we CAN run everything at once.
The Morgans
1989 Avion 34VB, "QE3"
2008 Toyota Sequoia 5.7L "Tug"
(Is there no respect for an 8-ton GCVWR truck? *sniff* )
Alluminati is offline   Reply With Quote
Old 01-07-2017, 08:16 PM   #9
dkottum's Avatar
I can tell you why we love our Dyson electric space heater.
It is absolutely safe, there are no hot spots on its exterior and the air coming out is only warm (but there's lots of it). It keeps the air temperature throughout our Airstream exactly as we (remotely) set the thermostat down to near 40 degrees outside, then the furnace is set as a backup. It is whisper quiet. It is near 100% efficient. It makes no dangerous gases, or uses any. There are no hot spots in the trailer when its on, or cool spots. It empties no fuel tank on our Airstream, and in some campgrounds there is no extra charge for fuel. It is a 6 inch wide cylinder, space is not an issue. We bought it at a huge discount.
The furnace does not even come close to it's comfort, quiet, and even air temperature control, we have used it for at least 1200 nights camping during the winter months all across the U.S. whenever we have hookups.
Doug and Cheryl
Old 01-08-2017, 10:38 AM   #10
dames7's Avatar
GILBERT , Arizona
Thumbs up 15 amps
Thanks to all, Just need to get a little peace of mine.
David & Nancy Ames
2015 FC 25' RB
Old 01-08-2017, 10:48 AM   #11
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
How about when staying at a site with hookups you are paying for the juice as part of your fee. With propane you paying for extra out of your pocket and using up your gas.
Lumatic is online now   Reply With Quote
Old 01-08-2017, 11:14 AM   #12
2007 22' International CCD
15amps
In moderate weather and 'free' electricity a portable electric heater makes sense. I also run the tank heaters if it's close to freezing outside.
In winterized storage it's also "good enough" to keep the chill off.
However, when it's really cold, running the propane heat is noisy, but it keeps the plumbing warmer, and heats up faster.
I'm not hung up on one method or the other. I use one of those oil-filled radiator type heaters. Silent.
KE4GNK/AE
Old 01-08-2017, 07:37 PM   #13
Alluminati's Avatar
If I were that cheap, I wouldn't have bought a luxury trailer.
People pay $70 for a heater to save $4 in propane???
The Morgans
Old 01-08-2017, 07:45 PM   #14
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
15amps
I don't have a high opinion of someone who pays $70 for an electric heater so he can save $4 in propane, especially considering the potential hazard.
This seems a little harsh. People make different decisions for different reasons and I'm sure none of them will hinge on you having a "high opinion" on what might be a very limited knowledge base.
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
