Old 09-30-2010, 02:38 PM   #1
1959 17' Pacer
Woodland Hills , California
15 Amps vs 30 Amps
I've just been entrusted with a 1959 JetStream 16-footer that only has shore power.
The built-in power cord has a standard 3-prong male plug that works fine at home. At the campground, it immediatly tripped their breaker even with all 4 on-board breakers (three 15-amp & one 20-amp for the water heater) off. I could reach another pole and got the same result so it wasn't their outlet.
I figured I had developed a straight short on the drive to the campground but when I used the adapter to plug into the 30-amp outlet, everything worked, even all at the same time.
Does this make sense or should I call an electrician?
Grateful for any help,
Dave
billida1 is offline   Reply With Quote
Old 09-30-2010, 02:43 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Were the outlets you were plugging into GFCI`s?
easyride is offline   Reply With Quote
Old 09-30-2010, 03:00 PM   #3
1959 17' Pacer
Yes and they were pretty old. I saw a maintenance note on one saying the GFCI had been changed out in 2002.
Old 09-30-2010, 03:38 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Billida that is a common problem and is usually due to a wiring mistake in the trailer, less frequently due to a short.
Have a qualified person check to be sure that neutral and ground aren't connected together deliberately in the breaker panel or at one or the other end of the cord.
Failing that someone will have to check to see if such a connection, or one from hot to ground, was made inadvertently due to insulation failure.
Old 09-30-2010, 04:35 PM   #5
1959 17' Pacer
Thank you very much, Jammer!
I'm not terribly surprised. The guy who did the reno seems to have been a very poor electrician from what I can see. I'll get an electrician to fix things.
Another concern I have is that I'm thinking of buying a Honda EU2000iA super quiet generator but the spec is only
AC Output 120V 2000W max. (16.7A) 1600W rated (13.3A)
If the water heater is on one 20 Amp circuit and there are three 15 AMP circuits to power a space heater, fridge & lights, will this be enough generator paower?
Old 09-30-2010, 04:37 PM   #6
1959 17' Pacer
btw, that's an old Norcold gas/120v fridge
Old 09-30-2010, 04:38 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It may be the cord you are using as well. If it is in poor shape. Did you try just plugging the cord in or is it an intergal part of the trailer wiring? If the neutral is grounded in your trailer, you will trip the GFI breaker every time.
TG Twinkie is online now   Reply With Quote
Old 09-30-2010, 04:56 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
Either the water heater or the space heater will use almost all the power the generator can provide. Don't you have a propane water heater and furnace?
Old 10-01-2010, 09:37 AM   #9
1959 17' Pacer
The cord is integral and in good shape and the breaker box it goes into looks pretty tidy but the wiring after that is very messy and probably has a problem.
I have a propane range and the dual power fridge but both heaters are 120v only. This trailer is definitely not self-contained. It has no holding tank, 12v anything or a generator.
I want to use standard sites without full hookups so I bought a portable waste tank and figured if I ran through the 20 or so gallons of water in the heater I'd be able to find a hose bib to fill a 7-gallon jug I have. I figured a 2000w super quiet generator would be considerate of my neighbors and maybe that will still work if I don't run both heaters at the same time. I guess I can buy a companion later if I need it. That would still be less than they want for the 3000W models.
What do you think?
What Amps??? Sundance Electrical - Systems, Generators, Batteries & Solar 8 03-31-2015 10:32 AM
Up grading to 50 amps... Bing-Bing Generators & Solar Power 8 06-27-2009 04:42 PM
AMPS 20? 30? 50? Which One Do I Want? Frank&Mike Batteries, Univolts, Converters & Inverters 7 06-24-2009 08:35 PM
How many Amps??? Sundance Batteries, Univolts, Converters & Inverters 3 07-03-2007 12:32 AM
Meter for amps davidz71 Electrical - Systems, Generators, Batteries & Solar 5 05-09-2002 11:21 AM
