Old 07-28-2015, 06:43 PM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The National Electric Code states that a circuit breaker can support only 80% of the breaker rating as a full constant on load. So a 15 amp breaker is rated only for 12 amps continuous load. An air conditioner causes a power surge during startup and for a few micro seconds the current draw can easily exceed the amp capacity of the breaker and then the current draw drops to run mode. Thus if the air conditioner cycles, there may little or no spare amp capacity for the other items that are also running on the circuit.
By using a #12 gage wire extension cord to the external power source, there will be less voltage drop and increased amperage draw and less chance of tripping the breaker at the power source.
Old 07-28-2015, 10:06 PM   #16
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Linked here is a thread where I measured current draw with my kill-o-watt. I was plugged in at home into a 20 amp circuit. No problem running the AC at an acceptable voltage.
http://www.airforums.com/forums/f37/...ps-135252.html
kscherzi is offline   Reply With Quote
Old 08-08-2015, 08:15 AM   #17
2008 31' Classic
Rochester , New York
All - thank you for the good responses and discussion. Turns out the 15 amp service as quoted on-line is actually 20 amp. We hooked up yesterday evening about 5PM and everything is working well. Temperature was in the 70's with a nice breeze off the lake, so we did not need the A/C. Today's high is in the 70's and my try the A/C just to check out. Our A/C is on a 20 amp circuit.
CharlieSK is offline   Reply With Quote
Old 08-08-2015, 08:38 AM   #18
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
A side note: How the Wally Byam caravanners made it through the African plains is a marvel to me. 2-30 A/C, 2 windows down, 30mph.
We have it good.
NavyCorpsman is offline   Reply With Quote
Old 08-08-2015, 12:14 PM   #19
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Here are my draws...
Nothing on
0.1
Refrigerator only
1.0
Refrigerator and all interior lights
2.1
Air Conditioning and everything above
16.0
My AC is an original Armstrong 11,500 BTU, not super efficient... But it is reliable!
Name:	ImageUploadedByAirstream Forums1439057669.662359.jpg
J. Morgan is online now   Reply With Quote
Service A and Service B nesoutlook Sprinter and B-van Forum 17 12-14-2015 08:36 AM
Thirty Amp cord for new Fifty Amp service Msmoto Electrical - Systems, Generators, Batteries & Solar 10 06-14-2015 04:58 PM
Airstream 1976 original Service Manual & Owner's Manual, good cond. leong1 Airstream Classifieds 0 11-12-2014 01:44 PM
50 amp to 30 amp only service Pearson422 Electrical - Systems, Generators, Batteries & Solar 13 10-08-2013 08:01 AM
