13.65? Agm Battery charging, plus battery monitoring question
Hi I just installed 2 agm deep cycle 6 volt batteries in series to equal 12 volts. My Victron battery monitor is reading around 13.6 is that ok? I do have a 3 stage progressive converter. Also when setting up the Victron auxiliary input what should I set it at choices below
1. for monitoring the starter battery voltage.
2. for monitoring the mid-point voltage of a battery bank
I’m not using it for temperature measurements of battery.
