Old 05-13-2010, 02:36 PM   #1
Confused in Bham
1964 24' Tradewind
Bellingham , Washington
12v Wiring
Hey all,
I'm done with the floor finally and beginning to wire out for 12v (110 to come later). I've received conflicting views on whether 12v has a ground, and when/if the ground is installed for 12v.
Need to Ground 12V DC system? - Boat Design Forums
I've attached two graphics portraying what I am trying to do. The small solid blue squares are individual lights, and the faded squares around them are complete circuits to be controlled by one switch each. The squares down the middle are the ceiling vents. 110 as noted prior will a completely separate system.
To start the process can I simply run my positive and negative to each location? or worry about ground at this time?
Thanks!
ID:	102445   Click image for larger version
beyond is offline   Reply With Quote
Old 05-13-2010, 03:20 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I would choose to run a ground (neg) wire to each fixture or outlet. Run 1 wire per circuit, right along with the hot (pos). Don't run just 1 wire for everything. That lone wire would have to carry all of the amps & be a larger gauge. Be sure to run them through rubber gromets so the vibrations don't wear the wire's insulation & cause a short.
I would not ground out the fixtures to the chassis like in a car.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 05-13-2010, 03:46 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Like Ricky,
I ran a ground wire to all fixtures, 12V outlets and fantastic fan locations. I did not run a ground to the running and tail lights. I used two wire 12 gauge for all my wiring which needed a ground.
Bill
Just my personal opinion
Old 05-13-2010, 04:12 PM   #4
Confused in Bham
1964 24' Tradewind
Bill and Ricky,
Would that mean that there is the positive, negative, and ground to all fixtures, 12v outlets, and fan locations? I am thinking that negative and ground are the same. Yes?
Old 05-13-2010, 05:36 PM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by beyond View Post
Bill and Ricky,
Two wires for 12 volts. Black is power, white is ground.
Old 05-13-2010, 06:17 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
The trailer is negative ground, just like the tow vehicle, unless you have an old British car. Black is positive and white is negative or ground
Old 05-13-2010, 06:21 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
GROUND!! It's not!
It would make things soooo! much simpler if everyone would refer to the -negative wire in the 12 volt circuit as "COMMON". I know auto makers call it ground, trailer manufacturers call it ground. But it's NOT ground. It is common to all of the devices in the trailer and TV. But it is not grounded to EARTH Ground. I would run 2 wires to everything if I were to rewire my unit. The reason AS and others don't is to save money.
Old 05-13-2010, 06:56 PM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I suggest that your Airstream's shell and ribs make a really nice ground wire. I find it redundant to run separate ground wires to light fixtures and pumps etc. UNLESS they are mounted in fiberglass end caps, or otherwise against wood or non-ferrous surfaces.
It is of paramount importance, though, that if you are using the shell and frame as a ground ( negative potential) , to make absolutely sure to have a very safe and solid negative battery connection to the shell AND frame. If you follow the Airstream original wiring diagrams, you will see that the negative wires ( white ones) always end up being grounded to the shell at some point.
Having said that, I use heavy ground wires to all motor driven DC devices, to avoid flickering lights when fans or pumps jump into action. In any event, it does not hurt to run separate grounds to each fixture, but I find it unnecessary.
Uwe
www.area63productions.com
Old 05-14-2010, 08:15 AM   #9
1963 19' Globetrotter
Moline , Illinois
I second using the shell. The more wire you you run , the more you increase chances for future problems.
63air is offline   Reply With Quote
Old 05-14-2010, 08:35 AM   #10
Sheridan's Avatar
1965 17' Caravel
Mountainous , Utah
On the other hand, if there is a ground problem, the fix is located at a central point where it would be easier to diagnose and repair.
Sheridan
TAC# UT-1
WBCCI#11112
Sheridan is offline   Reply With Quote
Old 05-14-2010, 10:56 AM   #11
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hey Beyond,
If you're running multiple 12 volt circuits, then I'd recommend using a different color wire for the positive wire on each circuit. There are plenty of colors available - black, red, blue, purple, orange, green, brown, etc. Then it's easier to keep track of what wire is what circuit and fuse. If you have trouble down the road, or want to add another light or whatever, you'll know which circuit it is by the color of the positive wire. Keep all the ground/common/negative wires white. Also, make sure the wire gauge matches the load and fuse you plan on using it for.
Chris
Old 05-16-2010, 07:26 AM   #12
toastie's Avatar
1955 22' Safari
Great Lake State , .
These are the diagram's that I followed. Ran a ground right to tongue, tongue to a grounding bar, bargman cable ground to grounding bar, electric brakes and battery to grounding bar, complete design control. Everything is working perfect..........toastie
ID:	102630   Click image for larger version
ID:	102632   Click image for larger version
toastie is offline   Reply With Quote
12v
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
12V wiring questions mmcpherson 1969 Overlander 5 02-14-2010 07:04 PM
'72 Argosy 22 - 12v wiring diagram nm_mike Electrical - Systems, Generators, Batteries & Solar 1 09-27-2007 03:39 PM
1966 Tradewind 12v wiring rlreed Electrical - Systems, Generators, Batteries & Solar 3 11-22-2005 07:19 AM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
