I'm replacing all the wiring in my 1970 overlander. I'll have a professional do all the connections to the inverter/ batteries etc. I'm trying to figure out how many Lights or 12v appliances I can have on one circuit? I have the same question for the 120v circuits?
All will be based on max amp draw. You will need to figure the max amp draw of each item and the plan to only use 80% of the fused circuit. (20amp fuse, wire for max 16 amps)
