Old 05-08-2013, 05:35 AM   #15
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
Originally Posted by Splitrock View Post
The red and gray wires with the yellow wire nut going left in the picture are the jack and breakaway switch wires on my trailer. The previous owner disconnected them. I reconnected them according to the Airstream service manual diagram. I removed the front sofa and the front inside skin to access the wires and to rewire the 7-way.
I looked under the trailer, and I have easy access, via a wire nut, to the brake wires. There is a cable labeled "Brake Cable" with two wires inside it, a red and gray(?) dirty white(?). Would I run a wire from the red brake wire to the front of the trailer and the B-A switch, with the second B-A wire going to power?
jerryc41 is offline   Reply With Quote
Old 05-08-2013, 06:25 AM   #16
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
I crawled underneath, and here's what I found. The "Brake Cable" coming from the front of the trailer contains a black wire and a gray(?) wire. A red wire runs from each of them to the brakes. Yes, two red wires run to the brakes.
So, do I want to connect the B-A switch to the black wire or the gray?
12v
