Old 02-14-2019, 11:25 PM   #15
2012 Avenue Coach
Corpus Christi , Texas
Originally Posted by Jekerrville View Post
How do any of us leave the house for fear we will exceed a specification of some sort??
I am looking at a PoE (power over Ethernet) power injector for powering a 2 amp 600 miliwatt broad band bridge that is 100 feet up on a tower using Catagory 5 cable.
The the injector is rated at 2.8 amps and is certified in the US and Canada for critical communications.
And we are sweating a USB charger circuit spec. at 2.4 amps in-rush current to charge a cell phone or tablet?
Remember that is 2 pair of a 4 pair twisted pair shielded fire rated cable.
Good grief, 100% worst case engineering is one thing bug just trying to reuse a cable to charge a cell phone is a bit paranoid.
Murphy Laws is quietly laughing.
Safe travels (With 5 lb fire extinguishers by you bed)
Murphy and I kinda have a thing and spend way too much time hanging out together. But I think in this case, you're saying "go for it".
And the fire extingisher is in the entry well. Not at arms length, but only 6 ft. away.
rowiebowie is offline   Reply With Quote
Old 02-15-2019, 07:49 AM   #16
Classy Roscoe
Jekerrville's Avatar
1969 31' Sovereign
Kerrville , Texas
rowiebowie,
Amen!
Jekerrville is offline   Reply With Quote
Old 02-15-2019, 08:30 AM   #17
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 78
How do any of us leave the house for fear we will exceed a specification of some sort?? Good grief, 100% worst case engineering is one thing bug just trying to reuse a cable to charge a cell phone is a bit paranoid. Murphy Laws is quietly laughing.
Fear of doing what Airstream certifies they meet as the MINIMUM required when they deliver a trailer or Class B to you? Yes, I would have some concern if I found that Airstream delivered my trailer without meeting the specifications they claim.
I have no idea where you got the idea that ANSI LV 2018 is 100% worse case engineering. That is factually incorrect.
Recommending that everyone follow accepted minimum safety practice is always a good idea.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 02-20-2019, 10:37 AM   #18
cedonly's Avatar
2013 20' Flying Cloud
minneapolis , Minnesota
Check out the power over Ethernet (cat5) specs:
https://en.m.wikipedia.org/wiki/Powe...ds_development
cedonly is offline   Reply With Quote
Old 02-20-2019, 11:47 AM   #19
Magnet18's Avatar
Churubusco , Indiana
I'd use it with a 1A fuse without a single worry
Usb 5v 2.1 amp isn't the same current you'll see at the 12V feed, a cheap 70% efficiency converter would pull .76A , so stick a 1A fuse on the cat5 cable and move on
I happen to have NASA EEE-INST-002 on my desk, table 4A, 26gauge wire, bundled, in a vacuum (no cooling), 1.4 amps.
That's for 200C Teflon insulated, cat 5 is 60C pvc, so cut it by 75% is .35A, times 4 pairs is back to 1.4 A, which is 50% more than you need
Like I said, stick a 1A fuse on it and sleep worry free.
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 02-20-2019, 02:18 PM   #20
Yuma , Arizona
I see no problem. In fact you could run only +12 thru the cable and tie ground to the chassis. I would get a 12 to 5 volt converter (ebay about $5) and drop the voltage at the end.
gcarter is offline   Reply With Quote
Old 02-20-2019, 03:16 PM   #21
2012 Avenue Coach
Thanks.
I discovered the wire is actually 24ga. I will try a 1A fuse and maybe go to a 2A tops.
I thought about that too. My usb outlet comes in tomorrow from Amazon.
Old 02-21-2019, 10:28 AM   #22
2016 30' International
redondo beach , California
I used the old cat 5 wires for the sun explorer to power the Victron BMV.
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 02-21-2019, 12:20 PM   #23
2012 Avenue Coach
That's one thing I wanted to do. But their monitors are pricey and with bluetooth built into the Victron controllers now, I decided to re-purpose the wire for a an additional USB since in '2012 Airstream did not install them in their Avenue class "b's".
Old 02-21-2019, 12:56 PM   #24
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
I suppose by now the decision has already been made to do it or not do it. We called this stuff "JK" or "Jake" which stood for "Jacketed wire" plus 4 conductor or 2 pair depending on what the color coding and if it was twisted or not... red-green-yellow-black or white and blue pairs. Most of what we used was 24 gauge. What its doing or used for determines the RJ designation. 2 pair could be CAT3... 4 conductor isn't CAT anything. Bottom line, doubling up conductors so you can have 2 conductors + and then 2 (-) would result in about a 4% voltage drop for 12vdc at 1 amp with a single run of 12 feet. You could cut that VD to 2% if you could find a ground near the "plug" and use all 4 conductors for +. I would fuse it for 2 amps and go for it.
Clint
By being so focused on how things 'could' be, we are under-appreciating how great things already are - Timber Hawkeye
Wolfwhistle is offline   Reply With Quote
Old 03-13-2019, 09:44 PM   #25
2012 Avenue Coach
Followup on my original post:
It turned out the CAT5 was 24ga and not 26ga as I originally thought. Therefore, I proceeded with using 4 wires for the positive and 4 for the negative with a 1A in-line fuse from the Victron Solar Controller "Load".
I love the Victron for program-ability and monitoring.
It turns out the USB outlet from Amazon is a 2.1A not a 1A. I was worried it might stress the wiring, but as someone pointed out, at 5 volts, the amps would not be that much and they were right. I just plugged in my phone and the Victron shows only a .4A load. I'm happy with result.
Thanks to all who took the time to offer advice. That's why I love this forum.
12v
Solar monitor CAT5 prewire? pteck Generators & Solar Power 5 10-25-2017 08:29 PM
Where is the CAT5 Data Cable for the Solar Controller Remote CarolynSteve 2016 - Current Flying Cloud 1 03-24-2017 10:48 PM
CAT5 for Blue Sky IPNPro Remote? mikebee Electrical - Systems, Generators, Batteries & Solar 1 12-01-2014 07:23 AM
Weatherproof CAT5 connector box perryg114 Computers, Internet & Satellite 10 06-07-2014 04:47 AM
2010 Int'l: Does cable coax go straight thru? or thru amp? amm3824 Audio, Video & TV 2 10-18-2010 08:32 PM
